mdeverhart
Does anyone know which models used the same (or compatible) interconnect cable?It would probably help if someone with a fully working one traced all the paths out and did a schematic.
I’m certainly having problems with second gens (165/180) the same as OPI wonder if the "second gen" 100 series PowerBooks (160, 165, 180, color variants) are as fragile.
There was a discussion thread on here that mentioned a source for the 50 wire ribbon cable, but not sure how you would place the connectors. That would require precision to pierce each wire. The cable do come up on eBay although they are usually pricey.I guess I’ll need to wait for some cheap interconnects to come up on eBay, and then be very delicate with them when opening and closing the machines. The problem is, I didn’t realise these cables are so fragile, and I’ve been working on the machines a lot during restoration.
It’s a pity there’s no easy way to replace the cable itself, although I might look at running some patch wires just to get it going temporarily.
Honestly not sure. I think aligning the connectors would be challenging.Couldn't you just use a SCSI (68-pin or greater) or IDE (80-pin) cable? The pitch is the same.
That would be a huge contribution if you can make this happen, and it is something that can be done on our benches. Many of us have been plagued by this cable. Please take lots of images that you can share here.I will make this happen.
Harder than aligning and crimping the cable?I've redone the interconnect cable before - releasing the latches without breaking them is the hardest part. You can use UDMA-2 (80way) cables.
That is great. Looking forward to how to instructions and images.Nice work @GRudolf94 , but too late for me. I've spent half the night replacing the defective cable on two of my interconnect boards, and it has been a big success. @TonyJay , I took loads of photos so I'll post a write-up tomorrow.
Not sure. New thread with title 'How to repair Powerbook interconnect cable' would be easier to find for those wanting to repair this cable. I bought replacement cables so I am good until I fiddle with them again LOLShould I add to the discussion here, or start a new thread?
I'd say new thread, might make it more 'findable'? Really looking forward to it!Should I add to the discussion here, or start a new thread?
