MBongo
Q: Where does one find Drive Setup 2.0.7?
Drive Setup 2.1 is available from https://www.macintoshrepository.org/689-drive-setup-2-1-2002-
And I believe that it was the last version made available with OS 9.2. (?)
This is my go-to OS 9 installer: http://macos9lives.com/smforum/index.php/topic,1657.0.html For those not registered there, it’s definitely worth the time and keystrokes to get this installer. Details: Very optimized version of Mac OS 9.2.2 for all Mac G3 and G4 Systems. This has Drive Setup 2.1.
I’ve tested various approaches extensively and found Drive Setup 2.1 to be the BEST for OS 9. And especially better than simply box-checking and installing OS 9 Drivers via Tiger. Believe me, that method yields slower performance compared to using Drive Setup 2.1.
Having just gone through all of this here again recently, testing various SSDs and mSATAs for comparisons in the G4 Mac Minis, I rushed to format everything using Tiger’s Disk Utility with “Install OS 9 Drivers” checked, thinking I would be saving time and forgetting my own guideline of always using Drive Setup 2.1. Benchmarks then rather quickly reminded me of the difference and everything was reformatted again using 2.1.
And the more common (earlier) Drive Setup 1.9.2 - is preferred for formatting FireWire drives for use with OS 9 booting machines… but it also yields less than optimum performance results when used to format primary boot drives. (Best for Firewire drives.) I keep both Drive Setup 1.9.2 and Drive Setup 2.1 in my Utilities folder on all OS 9 partitions / installations here.
As for the Adaptec SCSI card and any other added-in PCI card… all come out when installing / building “from scratch”. That’s a pain I know - but best practice.
