Macintosh Print Pack
When you want to print on wide-carriage or portable printers, the Apple Macintosh Print Pack utility may be all you need. It allows you to print from any Macintosh personal computer on wide-carriage (132-column) printers, and it gives you direct access to a wide range of portable ink-jet and thermal printers.
Regardless of the Macintosh model you use, you can produce large spreadsheets on computer fanfold paper with point-and-click simplicity. And if you work with a Macintosh PowerBook personal computer, you'll especially appreciate how easily you can work with a variety of portable ink-jet and thermal printers when you travel.
Each Macintosh Print Pack utility comes with the hardware and software necessary to connect your Macintosh to hundreds of models of wide-carriage and portable printers that are popular in the MS-DOS/Windows environment. And you'll find that switching between printers is as effortless as attaching a cable and clicking the mouse.
When you print from your Macintosh application, you can expect the finest-possible resolution the printer offers. And in addition to using the printer's font selection, you have the advantage of printing in any style the computer supports, and in any size-from tiny footnotes to bold display headlines.
For added versatility, Macintosh Print Pack software allows you to reduce or enlarge a document when it's printed; adjust the spacing between words on a printed page; and select colors for printing on color-capable DOS printers.
Compatibility
· Popular wide-carriage dot matrix printers that are compatible with Epson FX and Epson LQ standards
· Portable ink-jet and thermal printers that are compatible with Canon BJ-10ex and Kodak Diconix 701 standards
· All Macintosh font formats, including bitmap, TrueType, and Adobe Type 1
· Most Macintosh graphics formats, including bitmap, PICT, and TIFF
Print quality
· The highest resolution available on the printer, up to 360 dots per inch (dpi) for text and graphics
Versatility
· Printing on US letter, US legal, A4, and B5 paper; envelopes; and computer fan-fold paper
· Landscape and portrait formats
· Reduction or enlargements (20% to 400%) in 1% increments
· Color selection for printing on color-capable printers
Ease of use
· Fast, easy installation
· Convenient switching between printers
· High-speed (57.6-kilobyte-per-second) printer connectivity
Technical Specification
Printers supported
· Wide-carriage dot matrix printers that can emulate the Epson LQ standard
· Portable ink-jet and thermal printers that can emulate the Canon BJ-10ex, Kodak Diconix 701, Epson FX, or Epson LQ standard
· 80-column dot matrix printers that can emulate the Epson FX standard
· Some line printers that emulate the Epson FX standard
Ordering Information
Order No. M7900LL/A
· Parallel Printer Software disk with four printer drivers and a HyperCard guide to connecting to nearly 500 different printers
· Adapter cable
· User's guide
· System software
· One year of toll-free telephone support
· Limited warranty statement
© 1992 Apple Computer, Inc. Apple, the Apple logo, and Macintosh are trademarks of Apple Computer, Inc., registered in the U.S. and other countries. PowerBook, Print Pack, and TrueType are trademarks of Apple Computer, Inc. Adobe is a trademark of Adobe Systems Incorporated, which may be registered in certain jurisdictions. HyperCard is a registered trademark of Claris Corporation. MS-DOS is a registered trademark, and Windows is a trademark, of Microsoft Corporation. Mention of non-Apple products is for informational purposes and constitutes neither an endorsement nor a recommendation. Apple assumes no responsibility with regard to the selection, performance, or use of these products.
November 1992. Product specifications are subject to change without notice. Printed in U.S.A.
L0373LL/A
