3lectr1cPPC
My 180c should rest easy thenF4 and F4Lite BlueSCSI use an active termination system which shouldn't cause cross-talk when used mid chain.
Some models have resistor packs that are removed to disable termination, and others use bus switch chips to move the terminator resistors out of circuit. Removing the resistors packs physically disconnects the signals so there can't be any crosstalk, and the bus switches perform effectively the same function with a solid state mosfet switch.
thank you for the work you do on this as well as the portable hybrid project!
