How about this: old hard drive sounds emulator?
BadGoldEagle
Hi all.
I couldn't sleep last night because of a damn mosquito that kept buzzing around my ears so I relocated to the adjacent room's floor (there are only two beds and a couch in my one bedroom apartment, one bed was already in use and the room with the mosquito had the couch and the second bed.) ANYWAY, my life is very exciting as you can tell.
Obviously it was impossible to get some sleep so I did the next best thing: day (or rather night?) dreaming about some new Mac hacks.  |)
The SCSI2SD is great and all, but I miss the old hard drive sounds. I was thinking that it could be possible to record some sounds and then play them back. When you think of it, there are only two things that make noise: the heads moving back and fourth and the platters rotating. With the proper audio equipment, we could record some sample sounds (stepper motor initialisation if applicable, platters starting to rotate, platters rotating at a steady 3600rpm or whatever and also a couple of head movements).
The first part of the said emulator would play a couple of mp3 files in some order: first stepper motor initialisation, then platters starting to rotate and finally platters rotating. That's easy. Any mp3 player can do that.
Then for the actual head sound, we could use the LED activity light as a trigger. Every time the light flashes, that means the heads are moving, so if we play a couple of different head movements in a random order every time the light flashes, we should get pretty close to the sound an actual hard drive would make when used.
As for the hardware part, there are some mp3 players for the Arduino, so I was thinking we could use one or two of them boards and then mix the two audio channels together. Add a speaker on top of that and that would be it.
The best thing about this is that it would work with any emulator with an LED activity light (scsi2sd, scsi2cf, drem mfm emulator and so on...)
So, what do you guys think? I'm not sure I can pull this off myself, so if someone else is interested in this project, let me know. I'm gonna do some more research on the mp3 player extension and see if it could play two mp3s at once...
I'm also going to ask advice from some of my teachers. I hope they can help.
agent_js03
Haha... I have thought of this before too. Last night I was installing Mac OS 7.6 on my performa, and my wife could hear the hard drive all the way from the bathroom. She was like, "What the heck is that sound?! It's driving me crazy! Is it going to be going all night?" :p
joethezombie
I absolutely love this idea.  Not necessarily the 3600rpm whine, but the clicks, ticks, and grinding are very nostalgic and I miss them greatly.  I think we should be able to cook something up?
We'd need good quality audio of the sounds.
Hardware and software to play them.
Means to control the playback based on indicator activity.
Speaker output, which may require an amplifier.
Another option would be to use an actual hard drive, and utilize methods others have created to make sound machines (also Arduino powered):
One thought, on the Amiga emulator (FS-UAE), there is a floppy sounds emulator.  It outputs via the computer's sound system.  It always sounds very cheesy, and I end up turning it off.  Maybe because it is stereo and being projected all around me rather than from inside the computer.
EvilCapitalist
That's one of the reasons I've hung on to spinning disks in everything besides my TAM (aside from cost), I like hearing the hard drive sounds.  It would be cool to have this with the solid-state solutions but there would need to be a big enough library of seek sounds so that you didn't eventually catch on that it's recorded.  Never mind the technical aspect of the project, I feel like getting the sounds to not sound "fake" would be pretty difficult in and of itself.  Not only would you need a small quality speaker (that's pretty difficult on its own!) you'd need to get the imaging right so that it doesn't end up sounding cheesy like joethezombie mentioned.
You don't want to have a situation where you'd say "Oh, now it's using seek sound #7", like you get with certain TV shows and movies that terribly overuse stock SFX (apart from the Wilhelm scream which is specifically used because it's so well known).
galgot
That would be cool ! Actually what first missed when putting a cf card in Pismo was a small HD noise .
Have no idea how to do it, for older machines , maybe yes it would need an external device like an Arduino.
but for something like a more powerful, maybe it could be done internally by software.
Actually , I have WindowMaker installed on a Wallstreet, and there is a small dock app showing disk activity , but with graphics, no noises.
Same thing could certainly be done with some noises.
Bolle
You could always go so far to break open old nonworking hard drives and unstick them so they will spin again.
Set them up to spin up once power is enabled and then have an Arduino drive the stepper/head motor on activity light flashes. This will get you the most authentic sound at probably the lowest cost possible.
Drives that are still able to spin once you clean off any goo and rubber that gets them to stick or bend away crashed heads should be cheap and widely available.
Scott Squires
Shhhh, you're blowing up my stealth development project!
Oops, guess it's not stealth any more.
I have been setting aside various working hard drive models to use for high-quality recordings at a later date. Including Quantum, MiniScribe, Rodime, etc. The first purpose is for historical preservation of the sounds they made. And secondarily to sample the sounds for use in a retro hdd sound emulator thing.
I haven't started work on it yet, but it's been percolating in my brain as my next project. I have to finish ADB Busboy first.
There are some challenges. Even just finding an appropriate speaker, as EvilCapitalist mentioned. A lot of the relatively inexpensive small quality speakers I have come across are overstock, and you can't buy them reliably over several years like would be required if using them in a product.
Johnnya101
Hmmm.. Wouldn't it be possible to make a software type thing to run on the macs? They could send signals to the speaker so you could have a real one compared to a tiny one... problem is getting high quality sound on there.
BadGoldEagle
Thanks guys for the feedback. I guess this thing could sell!
Well, anthon... I'm sorry for unveiling your plans so soon but that's really cool someone with as much experience as you have thought about making this a thing too. Looking forward to this and the ADB busboy! I'm studying Automotive Engineering and even though we had some classes that somewhat relate to understanding how chips work, I have very basic knowledge when it comes to designing boards.
@Bolle: That's actually a great idea, and you're right it's the only way to achieve 100% true surround sound. The only drawback I can think of is that the whole device (old HD+arduino+scsi2sd) would be quite bulky and might stress some analog boards a little too much? But that idea deserves some exploring! Maybe we could remove the drive's circuit board and put the scsi2sd and the arduino in its place?
@Johnnya & @galgot: I don't think the original speaker can accurately reproduce those sounds (there are better speakers out there I think with a similar footprint.). And my SE/30 with its 50MHz Powercache has trouble opening and closing windows while decoding low quality mp3 files, so doing things with the MacOS on something like an SE with 1meg of RAM might be a little tricky... We'd have to code sound in assembly language or something, in any case, definitely NOT mp3.
@All: I'd like this device to remain universal (Mac, PC, Lisa etc). I'm about to order an MFM emulator for my 512k Hyperdrive and it'd be nice if it worked there too. Plus I bet some folks in the PC world would love it. And yes, don't forget the Lisa (thanks Falcon for bringing it up! Just imagine a 2/10 with an X/Profile with the old Widget sounds!!!)
techknight
a DSP and synth algorithms could nail this head on without "recordings", porting solid state storage code over to a DSP-CPU combo would be the way to go, then you can use the DSP side to render the sounds which are generated based on expect seek time, and of course seek length without impacting performance. if your at sector 0 and you need the last sector, or close to it, you will get a longer/louder sound. This can all be generated via algos.
Scott Squires
Yeah I would like to go the synthesis route. Personally, I'm no audio expert and wouldn't be able to just recreate the sounds by ear. So my first step regardless is to record samples so I can see what is going on in the waveforms.
Optimally we would have access to seek positions and read/write lengths, but realistically that's not going to happen unless Michael McMaster incorporates it into SCSI2SD. Presuming he doesn't do that, we're left with the challenge of faking it based on the drive access LED. It will be nothing close to "accurate," but we'll get our sounds. It also means there will be a bit of latency between the drive access and the sound.
Scott Squires
techknight's message prompted me to contact Michael McMaster about possibly making the SCSI2SD disk access data available externally. Turns out that he designed a UART header into v6 boards for future expansion purposes. Right now it's unused, but he said that he would accept contributed code to implement sending disk access information over that interface. (It would have to be a flexible protocol so that the interface could be used for other things as well.)
Using the disk activity indicator would also need to be implemented to make it universal. But it would be a very cool enhancement for users with SCSI2SD v6.
BadGoldEagle
Agreed. But we do need to make an universal version (even if it's not as good) for non scsi adapters.
aplmak
I had thought at one point using one of those little piezo speakers that have a pre-recorded message from a greeting card... get a short recording on it of reading and writing hard drive and powering it from the led activity light.. I think you can buy them on ebay.. I never investigated any further...
ahavelaar
New member
Has anyone already made a retro HDD sound emulator? I'm looking for something like that, or for good quality sound records.
elbaroni
Same applies to floppy noises, of course. I'd love it if my FloppyEmu made the floppy noises (including the buzz buzz buzz griiiiiiiind noise of a disk error when something goes wrong).
Would the LED light on a SCSI2SD work, or is that just a power indicator? (I've never hooked a light up to one of mine.)
dcr
Funny thing is that I was thinking this exact same thing today--that it would be perfect if the FloppyEmu could synthesize or even just play MP3 recordings of the various floppy drive sounds.  I'm certainly not an expert, but I would think the FloppyEmu "knows" when something is being read or written, so I would tend to think it should be able to play the appropriate sounds.
Now how much added cost that would be, I don't know.
