There's no mention of it in the usual places because Clock Generator resistor tampering of the CPU's multiplier pretty much negates the need for chipping the system clock.
However . . . [}
. . . merely running the 40MHz 68040 from the cap-rotted 840AV board via resistor via the well documented resistor musical chairs routine seems a silly waste of very cool (also within thermal spec) resources. [
What FDD?
Serial ports, don't plan on using them.
Is ADB one of the usual suspects in overclocking a board?
SCSI controller has its own crystal/timing setup, no? Zip drive required.
PDS NIC has its own crystal can for 10bT, how about my currently AWOL CS NIC?
Not all that concerned about the AV/Tuner Card, it has its own Crystal can for NTSC timings.
System video and how it will mesh with the blue screen system window of AVP with increased clock rate output of the video controller seems like it will be the sticky wicket?
Suggestions/ideas/guesses/further questions for pondering?
However . . . [}
What FDD?
