Thanks! That would have been awesome to collaborate with him. He seems to have a lot of knowledge about the portable compared to me, but unfortunately I don't have a good way to contact him.
On a side note, do you have a good idea on what type of cable I should use to take the odd connector apple used to make it something else becuase the 2.54 spacing header and cable will just not fit inside the portable's LCD bezel, it's too tall. I was thinking maybe I should use a regular very small/thin flat flex cable like the ones you can find on basically every electronic that connect boards together. Do you have any ideas on that?
