LCD Replacement for the Macintosh Portable
What inductor did you use on the RP2350's internal regulator? The RP2350 is very sensitive to what inductor is on the board and how it's arranged relative to the chip, to the point that Pi Foundation had a specific model of inductor custom manufactured with polarity markings so that people can make boards that run at max efficiency.
If you haven't verified your design against the official recommendations, you should. Also, make sure you have a pull-up on the RUN pin so that the chip isn't in reset all the time. This isn't really mentioned in that document and it matters (I learned the hard way).
I can see that you aren't using the recommended inductor layout. That may not be an issue but you should be aware of the potential for a non-functioning board.
If you've already ordered the boards, disregard this :).
Unfortunantly, the boards have been ordered :( I didn't know the official recommendations existed! I never saw a hint of them, I only saw the datasheet.
But thankfully, that inductor they recommended should fit on the board where I have the pads for it. I will definitely be praying my board layout works! Thank you though for this valuable info!
Alright, I found a display that will fit kind of well, I don't need the display so I am not ordering it but for those that need it, it fits with the dimensions at least. Display I couldn't find any closer ones.
I am asking this, I would like 4 volunteer's for once the boards arrive, I would mail them to you. But they wouldn't come with almost any parts, maybe like 4, it might not work, considering the above post. But it's on it's way. Who would like to try it out? Pls PM.
Cool. Mouser is great isn't it, for example in 2 days shipped at my home from TX, USA to Netherlands, free shipped from 75€. insane! i love that
Alright, An update is due... Good news! The PCB's showed up and I was able to solder most of the components on...
Bad news, the aliexpress order hasn't shown up yet and I tore the pads for the FPC connector on the board was working on, I noticed it after I had put all the other components on :( So now I am going to transfer all of the components to one of the other 4 boards and hopefully "crossing fingers" the parts that I lost (the inductor for 1V1 on the rp2350) show up. and I do all the extra work it all works!
Question for those who will use it in the upcoming (however long it is) future!
Would you like a usb-c on the final design for updating the code on the rp235xA, or a micro usb-b? The micro usb-b is a LOT cheaper to implement (or so I've found...)
But I am asking for your user serviceability, which one?
Or maybe a mac specific? :LOL:
Alright, been trying to find a way to upload the modified code, just changed pinouts and the like through text editor, to the Frogitron... But I can't seem to figure out how. Does anyone know how to do it or can do it for me? Thanks!
What exactly is the issue? The code in the original repository (which I assume is what you're modifying) is a Pico SDK project. You need to get a copy of the SDK and the build tools (ARM GCC and binutils), make them visible with some environment variables, and then run CMake. If you don't want to use the command line, you can also set that up through VS Code. The official docs show you how: https://pip-assets.raspberrypi.com/.../RP-008276-DS-1-getting-started-with-pico.pdf
I'm not one of your users, but I highly recommend using USB-C if possible. microUSB is fragile, mostly obsolete, and annoying, even if the connectors are a little cheaper. It is not difficult to add the two CC resistors and there are cheap connectors on JLCPCB's parts list. I've had success with the Korean Hroparts TYPE-C-31-M-12, but that was on a board that I had JLC do SMD assembly on. The low pin count of microUSB definitely makes it easier to solder than USB-C if you're doing it by hand.
That's the problem... I don't understand any of that!
Understood. I have soldered everything on by hand, including the rp2350 (but that I used the air gun) I was just looking for input.
This thread is not the place for an in-depth discussion (DM if you want), but here's the rundown: Pi Foundation develops the SDK to make it easier for people to program their chips, you use ARM GCC to compile code for the CPU in the chip, and CMake coordinates everything to, again, make it easier to program.
If you follow the PDF I linked starting from Chapter 2, the process for getting started is pretty simple. Install VS Code, install the extra dependencies if you're on Linux or macOS, then install the VS Code extension and load a project. The extension takes care of everything else and you'll be ready to program.
Alright, working on the code right now, but just got my portable apart aaaanndddd... The adapter hat doesn't fit! 😭 Now I have to figure out exactly what headers I can buy or make, so it's just a plug and play procedure. I don't want to use the original cable if I don't have to because my Portable's LCD is working fine right now... If you have any suggestions please let me know!
It looks like the pin on the Portable header is .02 inches x .0275 inches (I'll try to get mm soon!) And more measurements coming later!
Unfortanantly, my plans will have to change if I don't find a way to use the original connector... 😥 But my genouis brain said,"You could take inspiration from the video mac pac."
That's what it told me. SOOO I am wondering if anyone has a video mac pac they can hook me up with so I can probe and test with it? Otherwise I make one.
EDIT: @androda might know where to get them?? I was told by @wottle that he used them on your replacement LCD cables.
I have bummer news. I don't think a plug and play is possible for the Porrtable's LCD port. Because Androda moves the old connector over... As stated in the description here:https://androda.work/product/macintosh-backlit-portable-m5126-screen-flex-cable/
So I have to find a new route, sooooo, Building a card time! After measuring leads with my oscilloscope that I just bought. (Really excited about that!)
Or whatever idea's you might have as an alternative route...
Which connector is it you're looking for? One of the ends of the display cable, or the one on the LCD panel itself? And do you want the M5120 connector or the M5126 backlit one?
I am right now looking for the M5120 connector that plugs into the motherboard on the cable side. If the M5126 has a different connector I would want that one as well but at a later date. I am hoping this will be for early PowerBooks, and both models of Portable if possible when it is done...
I believe NFS-26A-0111 or NFS-26A-0110 should be original replacements for that one. There are likely others that fit as well.
Alright, wasn't able to get the plug yet (still looking). But came up with a FPC that you solder to the bottom of the motherboard. Hopefully it fits and works. It will be 2 weeks from now but🤞 .
