My Mad B&W G3 Setup!
Classic development from Apple consisted of MPW and ResEdit. <snip>
https://en.wikipedia.org/wiki/Macintosh_Programmer's_Workshop
Didn't Apple release the last version for free too?
Here's a question for you MPW experts: did someone ever implement tab completion for MPW?
I was brought up on Sinclair ZX Basic, syntax-perfect, Single-Keyword-Entry editing in the early 1980s and after that, nothing else has come close ;) !
So many choices! I might go for a USB MidiSport 2x2 to begin with, alongside a micro arduino to experiment with as that seems a fairly cheap route.<snip>
And indeed I've already bought one, for just £11 (+P&P). The adventure begins! I realise I can't do any DV video editing until I get the SATA setup, because the 16MB/s limit on the other IDE bus won't be fast enough. However...
Prepare to be Dazzle*d! This thing can capture composite video via USB on an iMac/266!
Ooh! I used to have one of those hooked up to my DV SE! And I had a HiFi VCR hooked up to the video out, which means I had an entire composite video pipeline. I found that the Dazzle* tended to blur the 320p signal a bit though; eventually, I replaced it with a Sony Digital8 handycam, which allowed me to use Firewire to stream 480p DV to/from the computer, and a high quality composite video I/O on the camera itself. It was more expensive of course, but the results were very much improved.
Unexpected, since it has FireWire!
I would expect so. Dazzle has to get the video data rate to somewhat below 12Mbits/s as it's a USB 1.1 device: pretty heavy compression.
And I have the original installation CD! It's Mac OS 8.6 compatible! Wooh!
Undoubtably! I do have a Canon MV500i DV Camera. I don't have an analog camera... aaah, but I think the Canon can output composite, so I might be in business ;-) !
I recommend the @dosdude1 patcher, see here.
Hi folks,
So, I have tried to use the dosdude1 patcher and of course, it hangs because it has an AM28F010, which, as per this comment, needs 12V to program it.
Gosh. I can't believe it's even possible to buy a flash chip that needs 12V any more and I had completely forgotten that the original Intel 28F010's needed 12V (is this +12V? or -12V?) despite having worked with them in the early 1990s on my first embedded programming job (we made ISA-card based SSDs that emulated hard disks (not floppy disks) via an Int 13h interface. Each card could take up to 24x 128kB chips and I think we could support 2 or 3 cards (or 4?) in a single system, providing 6MB to 12MB of Solid State Storage).
Wow. I guess this means I'm going to have to build a programmer. How can I do that? Well, I have a Maplin bench power supply which can generate 12V (or -12V I guess if I swap polarity) and I have an arduino MEGA 256 which works at 5V and has lots of pins. I suspect this means I have to do it the hard way:
  1. Desolder the flash chip (PLCC I think so at least the pins are big enough).
  2. I have a socket for a PLCC that might be the right size. I'll need to build an arduino shield to program it. Except that, of course, I'll only have stripboard to interface the PLCC socket with the shield, that's going to be interesting.
  3. Write some arduino code to program it. The Arduino has 256kB of flash space, so it should be possible to just embed the whole of the ROM in the sketch without a serial download. Fun! I'll program it slowly, because my rats nest of wires from (2) won't take high frequencies.
  4. Program the chip - here I'm assuming the address pins and data pins match the card? Of course, Address and Data could be in any order!
  5. Solder the ship back in the SATA card.
  6. Reboot.
Does this sound correct? One more question. There's two header pins on the top-left of the card (if you hold the card with the logic facing you and the PCI bracket on the left). What's that for?
Hi folks,
  6. Reboot.
I had the same issue, but used a T48 to program it.
  6. Reboot.
Read the chip first in your programmer and compare with a ROM dump from Open Firmware.
This will verify the address and data lines are correct.
I just finished adding emulation of flashable ROM chips (AMD Am28F020 or Intel 28F020) to my fork of DingusPPC (code not committed yet). These are chips used for the ROM SIMM slot of PowerSurge/TNT/Apple Network Server machines. Apple made a utility to flash these chips in Mac OS.
https://tinkerdifferent.com/threads/apple-network-server-macos-based-roms-found.4756/post-41630
https://68kmla.org/bb/index.php?threads/apple-prototype-rom-flasher-utility.45480/page-3#post-511697
(and @croissantking , @adespoton ). I don't really have a proper programmer. To program the Flash I'm thinking of doing something fairly nasty:
I don't have a suitable hot-air gun, never likely to do enough of this to justify buying one & I'm not good at wicking away solder. I have an Arduino Mega2560 and I've just ordered a prototyping shield. I've also been writing some programming code for the Arduino. There's easily enough I/O on that to handle every pin on the Flash chip and I have a little rectifier to generate 12V, or I could just set my bench PSU to output that, since I think it can be on all the time. I've written code to program an Am28F020 in the past, so I don't think that's a problem.
The nasty thing is that I'm thinking of just clipping the pins; removing the remainder from the pads; then wiring it up directly using the remainder of each pin to my programmer and when I've finished doing the same back on the board. How stupid is that?
Another mechanism, I think would be to use a scalpel type knife: I'd place the knife against one corner of pins; heat it up with a soldering iron until it melts the solder and I can slide it along one edge, under the pins, dragging the solder in order to disconnect. Could that work?
The less stupid option, I think is to start off the same way, but then buy an AM28F020 from RS components (or Farnell).
It’s certainly not conventional.
But if it works, it works.
I don’t fully understand what you mean sorry.
I agree.
Also, there are various types of low melt solder (chipquik smd1 being the most well known) and I recommend it highly. You flood the pins with the stuff and then you can remove it just by heating all around it with a soldering iron. The special solder stays melted for far longer than normal solder.
Edit - ah, sorry, I misunderstood.
I wouldn't do what you're suggesting. Hold off a few days and we'll see what we can work out.
Here's a question for you MPW experts: did someone ever implement tab completion for MPW? That was something that was always a pain point for me once I started doing dev work on VAX, IRIX and other unixes in the 90s -- csh had nice tab completion, and every time I went back to MPW, I'd try to tab complete and then have to undo and manually type, or manually set up command key shortcuts.
I don't know about tab completion in MPW. People made patches to MPW to add features.
- PopupFuncs 2.8.1
- MPW Technicolor 0.9.6
- MPButtons 2.2
With MPW, every menu can be modified and commands added (including shortcuts). I suppose a command can help with tab completion. It could present a Commando interface with a list of possible completions?
- PopupFuncs 2.8.1
- MPButtons 2.2
Yeah; I've used PopupFuncs and MPW Technicolor, which help. I've fiddled around with a Commando interface with a completion list, but found it somewhat lacking -- it still throws a mental roadblock in the workflow. I've got used to doing a LOT of tab completion in my IDEs/text editors over the years.
I bought a hot-air gun ~20 years ago, and it always amazes me how many times it's just the right thing for the job (especially spot-drying paint). Having one with an adjustable flow speed and focus point is also really useful (sometimes you just want a small jet of really hot air, sometimes you want a warm bath of air over a wider area).
To add on to @croissantking 's comment, what I've found useful is melting existing solder and then quickly flooding with the low temp stuff -- it mixes in and stops the standard solder from hardening so fast you can't get all the contacts off the pads. There's probably better methods, but that's what I've tended to do (sometimes with the heat gun blowing and a solder sucker in the other hand to pull it all off as soon as possible).
What brand and part is our ROM @Snial? Do you want me to send one pre-programmed? I have 3.3v and 5v versions that work with the stock Mac Firmware in a drawer.
Thanks for the reply! When you say "our" ROM, do you mean the ROM in the SATA PCI card or the ROM in my Blue and White G3, or another ROM? I thought it was an AM28F020, but its logo implies otherwise I think?
When it cools down a bit in the office, I'll pop up; check it out again and get a better photo.
-cheers from Julz
-cheers from Julz
I mean "your", but the y didn't register or auto correct mangled the sentence :)
I assumed it was the SATA card you were looking at flashing.
I can't see the photo very well, the markings aren't clear
Yes, I usually try to make sure the ICs are readable, but that was shameful! I opened it up and took a new photo:
So, it's an AMD, AM28F010! It's quit interesting how such a simple, and ancient chip could present this kind of hurdle!
-cheers from Julz
-cheers from Julz
OK, so it is a 5v part.
Would you like me to send you an equivalent pre-burned?
That’s very kind (you know my address)! But only on condition I send you a replacement or reimburse you by some other means. I still haven’t tested the OPL chips!
So I think I know how I’d do this, then. Snip the legs of the existing one and then I can de solder with ease? Then I can solder the new one on if I’m sensible enough to use flux?
I have a 40GB drive in the slow IDE channel.
However having the SATA card working is that i can restore the Zip drive on the BandW G3 . I figure I can experiment with some video editing on a 350MHz BandW G3, probably using EditDV 1.6 (or 2.0). So, the G3 is pretty much the slowest for the job, but at least the HD will be fast enough :-) !
-cheers Julz
Wait until the new one arrives. Oldest trick, never trash the oil filter on the car taking it off until you know the replacement fits :LOL:
They're pretty easy to overclock of you haven't already. Simple enough to step them up 50MHz for a small speed bump.
.... I'll give you 1 guess on whether I knew that trick ;-)
By changing the PLL?
Oh gosh! It's just a jumper block!
Code:
(S = Jumper present or "Set", " " = no jumper)
            Multiple     | 4 | 3 | 2 | 1 |
            3x   300 MHz |   | S | S | S |
            3.5x 350 MHz |   |   |   | S |
            4x   400 MHz |   | S |   | S |
            4.5x 450 MHz | S |   |   |   |
            5x   500 MHz |   | S |   |   |
So, upgrading from 350MHz to 400MHz involves adding a jumper at jumper 3. I'm not massively into upgrading the performance of vintage Macs, mostly because I want the experience of the period. But I'm happy to do period-correct, options. Hence, my PB1400cs/117 upgraded to PB1400c/166. So I'd certainly be up for upgrading a 350MHz B&W G3 to 400MHz!
But I wouldn't upgrade a PB1400 to a G3, or a 250MHz PPC603e. I wouldn't upgrade the B&W G3 to 1GHz or swap for a G4 if that was possible.
I wonder if I can just pull out the metal prongs from a jumper I have and insert them into the block?
