Doom on SoftPC on an SE/30?
You're absolutely right - I was thinking about it in the context of a single thread where it's bad enough, but this attitude is not great for a retrocomputing forum or indeed any interaction with another human being in any situation whatsoever. Makes me wonder what the rest if their life is like.
Back on topic! Would be super interesting to see the difference between a straight-up port vs a generated assembly optimization. I have this sense that later 68k machines rarely got treated right in terms of game optimizations - with some exceptions: Marathon you have mentioned, also Avara runs ok on an stock SE/30 - it doesn't have texture mapping, BUT it is fully 3D and I think the source code is also available.
This is really cool. I'm looking forward to working with some kind of AI to learn. Nothing this cool, but I'm optimistic that it'll help me better understand what I'm coding.
I can't with the haters. Let's not turn this place into StackOverflow.
Great ideas all. On the front of “feeding it” other source codes for idea- that’s super interesting. I did that just yesterday with a doom port called FastFoom and asked the AI to study the code and see if there are any ideas etc that could apply to this project and it made a list where about ten of them were already implemented in macdoom se/30 but a few weren’t. It took the missing ideas and implemented them but it didn’t move the needle much. In particular it was a smarter way to avoid searching through the BSP more than necessary. Surprisingly it actually made performance a hair worse but the experiment setup isn’t perfect. Anyway I like the idea of trying to feed it other source codes of simmilar games that seem to perform better overall - like Marathon as mentioned earlier.
I hadn’t heard of Graphics Gems books — will look into them!
I feel bad that my doom project took over this SoftPC thread — but it has momentum and no one seems to mind.
Back to working with AI for a sec for coding:
  • Very low effort to ‘get off the ground’.
    • This is my first hobbby project using Claude Code and certainly the first using it for something on System 7 / vintage computing. I purposely spent an hour in a planning session with it before kicking off any work, which is highly advised (use /plan in claude cli) in most cases of using AI to code something.
    • But after that was done the first step was to just make a successful build that would show 1 frame on the screen and within a half hour of actually trying to have it code anything it had the game building and running on my se/30.
  • Claude has different models you can choose (they all are like this) and its latest one is called Opus. It costs more ‘tokens’ than the older Sonnet model but I found the best workflow to be to use Opus for planning and Sonnet for code implementation.
  • Bugs / workflow points
    • And when encountering tough bugs that Sonnet can’t figure out, switching to opus to tell it to try to solve it.
    • When any model has trouble figuring out bugs it is always helpful to suggeset how to solve bugs. This is where the more you know the bettter you can work with it to figure out the problem.
      • eg. telling it to instrument log file messages to fully figure out the problem
      • e.g. telling it a test plan: When sounds just wouldn’t play, it was stumped, but I told it to make a test where every time i press ‘Z’ it runs through a series of sound-producing functions from SYSBEEP all the way up to the full doom game sound function chain. After that the bug was found within one iteration of build+test.
    • The AI starts to flail when it can’t resolve a bug. More specifically, the AI was well aware of the criticality of performance in this project. Yet when it couldn’t find a bug a few tries it suggested a sort of blanket solution that indeed would have overcome the bug’s symptom but not by root-causing it but rather by expensive coverup — In particular it was suggesting we just redraw a whole screen portion or something every frame to avoid some bug. Certainly I yelled at it for suggesting that and of course it goes into “You’re right… I should work to find the root cause…” which eventually we did but geez.
    • I specifically told it many times NOT to modify code unless I have approved it. It continued to break this rule sporadically. I’d call it out every time and it’d apologize profusely until finally “admitting” that it’s a limitation of AI to have any hard-constraint rules it guarantees to follow. That was probably the most discouraging moment of all - not for making doom but for thinking about how much guardrails a user can put on AI when it matters...
  • AI like this is very good at rapid prototyping and getting you 80% of the way there extremely quickly. But letting it get you to 99% is harder for it to do. And in a world where you’re making a commercial product, 80% won’t cut it — but if you let AI do all of the work up to 80% you’ll have a steep angle to climb to get up to speed with what it did to help it get further along. Not so much a problem for a campy project - definitely a problem for professional / commercial projects. Better methodologies exist and I’d say are necessary
  • Opus model impressed me because it could read my resource fork files (converted from reseddit to .r files using derez) and find a quirky bug in how I set up one of them. Sonnet was completely stumped and really flailing
For purist hobbyists, I encourage them to check out my other vintage mac program MacDock — it’s like the modern macOS dock but for System 7. I wrote it a few years ago and programmed it entirely in THINK C - often right on my SE/30 natively and sometimes from an emulator. No AI at all.
Hot diggety, a system 7 dock! Now that’s cool. And aside from asking AI for some assistance that’s how I want to do it-Think C right on the SE/30. Got my Ritchie and Toolbox primer at my side!
Thanks! Yes a looooot of pdf searching to go through the documentation from apple in order to sort through things…. look up which book it’d be in.. then open that book and look it up there… Fun times!
Someone posted it on macintoshgarden which made me happy. My little brick in the vintage macintosh wall of history :D
I always thought of the Control Strip as the Dock predecessor (or the Dock is the evolution of the Control Strip), so I’m curious to try this…
I usually think of the Dock as being the descendant of the Launcher app... but I guess the Launcher app (or whatever it's called now) is really the descendant of that, and Control Strip is more in-line with the Dock (or possibly QuicKeys).
Possibly the Dock goes all the way back (via NeXTstep) to Accent, a predecessor to Mach that was developed (by Avie Tevanian and others) at Carnegie Mellon in the mid '80s. Here's a graphic (not a screenshot) that portrays what the UX on most Accent installations was like; that icon window at the bottom is very Dock-like. From here...
^^ This. The dock was a direct descendant of NeXTstep - not the control strip or the launcher, etc. NeXTstep had a dock but often shown on the right (IDK if it was moveable).
iu
iu
Although there may have been work in that area, it turns out the NeXT Step Dock (and Windows 95 taskbar) was derived from the first commercial implementation on the Acorn Archimedes' Arthur OS in 1987.
(So, note, Arthur/RiscOS could drag windows around on a 4 MIPS ARM).
This one is a 24MHz Acorn A5000 I think, from about 1991. Showing full screen scrolling. It isn't mine (I was helping repair it for someone) and it is a while ago, so I might have some details wrong.
View attachment 20230902_144138_1.mp4
I would really like to see some direct proof of this, considering that the Sapphire window manager on the Accent system essentially had a dock three years prior (see above post). Besides my citation in my previous post about Accent, you can read this article about the Sapphire user interface, with details all about the "icon window" starting on PDF page 5. (The author is Sapphire's interface designer Brad Myers, who is often credited with inventing the progress bar. Accent had them, and Myers may have debuted them there.) So by timing alone, the Register article is wrong: RiscOS didn't introduce the icon bar concept in 1987. The Accent article I just linked is dated December 1984.
But why does Accent matter to NeXT?
Well, Accent was a direct ancestor of Mach and therefore NeXTstep; it was developed right in the same Carnegie Mellon lab where Mach was born. Avie Tevanian who I've mentioned was hired directly out of that lab by NeXT, albeit to work on the OS and not the interface. I suspect he was not directly responsible for the NeXTstep Dock, but that his computing community was. The NeXT was designed in the mould of a graphical workstation of the time, a late realisation of the CMU-originated "3M computer" concept that was quite influential (the link lays out the connections). Anyone who would have worked in the workstation space would have been familiar with Accent, as it was discussed at symposia like this one in Oxfordshire in 1985 if not experienced directly at major university CS labs in the North America and the UK. (Mouse over "Further reading" to see all the contents, and note participants including Myers and future Java inventor James Gosling.)
My evidence is circumstantial but I think it's pretty good; I'll need some convincing to believe that the Dock came from the Archimedes, and a quoted attestation in an article that has a factual error in it doesn't do it for me. But I'm ready to stand corrected if you have proof.
(And there can still be a UK connection: Accent ran on the PERQ, which was for much of its time an ICL co-production, though ICL preferred its own PNX OS to Accent. Accent would run on my PERQ too if I could just figure out what to fix in it...)
This lines up much better with my own recollection (I know, two anecdotes does not constitute evidence). I can definitely see Windows 95 getting its taskbar inspiration from Arthur OS, but the NeXTStep bar can draw a direct development line back to Accent.
And, of course, similar panels were already very much a thing in physical systems management going back at least to the late 1960s -- it was a different paradigm than the menu-driven one LisaOS opted for, but PLCs driven by programmable panels were a thing, and then in the late 70s Modbus enabled SCADA systems to be repurposed for managing PLCs instead of just handling telemetry and alarms, resulting in mixed general purpose panels that functioned pretty much the same way as Accent's software panels, with definable icons. Only difference being: you used icon overlays once you'd defined the panel functions in PLC land.
That said, none of this existed in a vacuum. Likely most of the systems developers, at least in the OS world, were aware of the other approaches out there and borrowed from them as it seemed useful. Which circles back to why Mac OS eventually got the Control Strip, and its functionality was later integrated into the dock when OS X came along (yeah, those dock modules were originally a thing, and eventually quietly went away again, to be replaced by more menu item apps, desktop widgets, and eventually the control center).
Nice. Here's my video of my PS/2 to Quadrature-Encoded mouse conversion that I did for my 12MHz A3020 (6 MIPS). It shows me moving the paint tools palette around the screen along with the contents.
You can also play with the Javascript multi-Archimedes machine emulator: https://archi.medes.live. For example, Choose Machine:A3000 and Risc OS 3 to see what an 8MHz ARM could do. The emulator aims to emulate in real-time. Then pick Load Software:RISC OS 2 Application Disk (1) . You'll find that dragging windows with their contents and scrolling images works well.
In many respects, an 8 MHz ARM2 shouldn't be able to compete with even early SPARC and MIPS RISCs, primarily because it has half the registers, had fewer instructions and no cache. Yet, in reality it's able to perform tricks that SunView, Solaris, Windows and Mac OS just couldn't do until about a decade later, with chips running into 100s of MHz, L1 and L2 caches and/or dedicated GPUs.
And this begs the question, how? The answers are, I think fairly obvious: RISC OS was written in Assembler. Also, its colour graphics routines were probably simpler than QuickDraw or its competitors. But also, ARM could do a few things optimised for DRAM, namely page-mode sequential access and conditional instructions which helps optimise for sequential access. Also, interestingly, ARM2 had a Booth-algorithm multiplier (and MAC instruction), which could perform multiplies twice as quickly as an unrolled SPARC MULSCC could.
Apart from the Icon-Bar though I find RISC OS pretty clunky. Its 3 button mouse system and UI conventions were overly technical for a computer aimed at kids, while the styling reminds me of GS/OS.
I would really like to see some direct proof of this <snip> Sapphire <snip> dock three years prior <snip> by timing alone, the Register article is wrong: <snip>
There are things that really irritate me about The Register article and the presentation it's derived from. The tone is very hacky. It's like, "Oh we just hacked a UI in a weekend that beat ARX, and it was just a demo in BASIC that displayed multiple clocks." "Arthur wasn't an OS, but the Sales guys put it in a ROM anyway - you know what marketing is like, hoho." and "Oh, we knocked up multitasking by jiggling with the MMU."
It's written as though Computer Science isn't a real thing at all and planning is for suits. Arthur actually took about 18 months+ to write and as a GUI is seemingly as capable as Windows 2 and no more clunky than Sun Tools. Its UI is reasonably well thought out and consistent. Sales people don't really make decisions about ROMs. Their description for managing multiple applications via the MMU in reality sounds entirely conventional: applications regardless of where they are in Physical RAM just get mapped to a standard Virtual address (on RISC OS, starting at 0x8000). The only weird thing about the MEMC MMU is that it's a Physical Page Table that maps to Virtual addresses rather than a Virtual Page Table that maps to Physical addresses. The chip has a CAM (Content Addressable Memory) that performs all the PPT scanning in parallel.
Thus, jiggling the MMU from app1 to app2 involves scanning through the PPT; and for any Physical address corresponding to a VA in app1's range, changed to invalid, and any PA for app2 changed to a VA in the right range. It sounds a lot like Switcher and Multifinder.
Anyway, my rant about the article I was citing, is now over.
<snip> Accent was a direct ancestor of Mach and therefore NeXTstep <snip> Avie Tevanian who I've mentioned was hired directly out of that lab by NeXT <snip> Anyone who would have worked in the workstation space would have been familiar with Accent, as it was discussed at symposia like this one in Oxfordshire in 1985 <snip> can still be a UK connection: Accent ran on the PERQ,
And that's reasonable. I guess, Acorn could have derived the Icon Bar from Accent and then just hoped no-one remembered Accent. Not sure how to prove that.
Well, that would be a perk!
Would a multiplier be used all that much to make the RISC OS user interface? I think the ARM probably did have a hardware advantage that most other contemporary processors (besides the 386) lacked: a barrel shifter. I don't know how useful it is for colour graphics, but for bitmaps it can really speed things up.
Many microprocessors up until the '90s would shift or rotate a word by N steps by placing N into an internal register and counting down that many single-bit shift/rotates. The bigger N was, the longer the instruction took to execute. With a barrel shifter, a shift of any size takes the same number of clocks. Fun fact: most processors that used the countdown approach were actually smart enough to only place N mod W into the counter register, where W is the word size, but some weren't: you could lock up a transputer for more than a minute by telling it to shift a value by 2^32 steps, or 2^31 or something like that.
I think it's quite possible that they came up with it on their own: it's just icons in a row in a skinny box. I'm not even sure Accent was really the first: you could imagine that tool palettes for light pens or drafting tablets may have looked very similar, for example (also see @adespoton 's remarks above). I just wanted to dispute the idea that the Archimedes was where the design debuted, or that NeXT cribbed it from them.
Would a multiplier <snip> RISC OS <snip>?
I just threw that in. Many workstation applications were maths-heavy. An 8MHz ARM could beat a 16.7MHz SPARC for some DSP computations (mostly because multiplies were compiled as a library routine by default).
<snip> ARM <snip> barrel shifter. <snip> colour graphics, <snip> bitmaps <snip>
True. ARM also had multiple load/store which could have helped 8bpp colour graphics?
<snip> shift or rotate a word by N steps <snip> single-bit shift/rotates. <snip>
Even the earliest commercial SPARC/MIPS RISCs had barrel shifters though didn’t they? I vaguely remember the earliest PA-RISC had shift by 4 and shift by 1 though.
lock up a transputer <snip>
I had access to UEA’s 9 CPU transputer rack for my 3rd project. I didn’t know that. I was aware that the Aztec C compiler we used on the 68K SBCs compiled literal 0 shift/rots as 0, causing a shift/rot of 8 (so we had to code workarounds). Maybe OCCAM compilers stuck a 1, 15, AND sequence in before a shift?
<snip> possible that they came up with it on their own: it's just icons in a row in a skinny box. I'm not even sure Accent was really the first: you could imagine that tool palettes for light pens
Even the Quantel paintbox in 1980 had that kind of UI, so good point.
I actually did something similar on my ZX Spectrum for my Computer Studies ‘O’ level in 1984. I had heard about GUI OS’s by then and found them really exciting. I didn’t really understand them much, except for the concept of an icon, but a ZX Spectrum wasn’t powerful enough for that, certainly in BASIC. What I could do was use the bottom two lines, which you couldn’t normally PRINT AT, as a 16x16 pixel Icon bar for its primary functions, and I think it would be replaced with icons for sub-functions. PRINT #0;AT 0,0;… would point to the bottom 2 lines.
So maybe I’m the inventor and Acorn nicked it from me, the scoundrels ;-) !
<snip> I just wanted to dispute the idea that the Archimedes was where the design debuted, or that NeXT cribbed it from them.
It looks like the whole history is more involved than I first thought.
I'm having a hard time finding out for SPARC, but yes, it seems per this old thread that MIPS did have it "from day one". So the GUI performance must have owed to something else. One other possibility is that Archimedes windows were just smaller than the ones found on megapixel displays like the workstations had...
If I remember, wasn't the Archimedes platform particularly efficient WRT RAM access? That would likely help if the VIDC had very fast RAM access.
The first Sparc CPU (V7) was the Fujitsu MB86900 in1986. This is the manual for the MB86901, which is also a V7. The introduction explicitly mentions a barrel shifter and later in the manual shifts are described as having 1 cycle.
But here I have proof! The original MB86900 was implemented as a CMOS gate array and there are articles on the design of that gate array RISC, such as:
Here, they make it clear that the MB86900 implemented a barrel shifter:
Well that is true too. However, the original Archimedes supported an 8 bpp video mode at 640x256, which occupies 160kB. It's certainly possible by choosing an A3000 running RISC OS 3 (still 8MHz), then the palette icon in the Icon Bar, Option+Click the Palette window and choose mode 15. Then drag the window around, or the main task window in real-time. This compares with 1152 x 900 / 8=129,600 bytes, somewhat less memory than an early Archimedes.
The original ARM processor made good use of Fast Page mode for DRAM for both MEMC and the CPU. So, that would help a lot.
