SE/30 recapper recommendation — Melbourne or AU-based?
G'day from Sydney.
About to buy an SE/30 (it's in Melbourne) and want a recapper lined up before I commit.
Per the seller's photos: chimes and boots to a full System 7 desktop, runs fine once going — but horizontal lines on cold start and an intermittent boot (flashing "?" disk, then fine after a power cycle). Textbook recap, maybe a tired SCSI drive too.
Australian members — who do you rate for an SE/30 recap?
Melbourne-based would be ideal so the board doesn't travel far, but I'll post it anywhere in AU. I'm in Sydney so I could post it to myself first and then find someone in Sydney to do it.
Also happy to take a quick DIY reality check if you've done one yourself.
Cheers, Jason
G'day from Sydney.
Cheers, Jason
It will need more than a recap, the board will need cleaning from electrolyte and potentially repair to damaged traces.
Textbook failed caps on these is no sound, that’s it, anything else requires further work to diagnose and repair. Recapping is often just a starting point.
If you’re lucky then the intermittent boot could be a poorly seated ROM (common with these) and the flashing ? a failing drive as you say.
I'm in Melbourne but don't have time right now, I'd recommend you learn to DIY as with any SE/30 it's not just the motherboard, you're also looking to the PSU analogue board and likely floppy/HD will need attention.
Thank you -- it's looking that way, it turns out I ended up buying TWO SE/30s by accident, one is in full working order the other one needing some TLC, so I can use one as a reference and the other as a learning experience
Appreciate it, it looks like I'll be doing that plus I might head down to a local ACMS Sat morning meetup and get some old hands to review it for me as well so I know exactly what I need to do.
Haha, how did you manage that?
You can never have too many compacts. Isn’t that like the first rule of the ‘MLA?
There is a Mac museum in Melbourne.
macmuseum.com.au
https://www.macmuseum.com.au
Try there someone should be able to help
I'd probably try to learn to re cap on something less expensive if you want to do it yourself. Welcome to the rabbit hole that is old Macs! I'd help but I'm in Tassie
macmuseum.com.au
I'm in deep, I now have Classic, Classic II, 2xSE/30s
I will start on the Classic, I just got all the recap equipment as well.
thanks mate, they shut down a few years ago and stopped accepting new work
I don't blame them. It is a socially difficult job, I suspect sooner or later you either end up out of pocket or struggling with an angry customer.
A difficult to find bit of damage can take many hours to troubleshoot and while expensive, these machines still don't cost enough to justify multiple days of skilled labour. I've heard horror stories of people demanding working replacements for their non functioning boards, but even "I just want a recap, why are you talking about repairs, my board was fine" is common.
People that do repairs as a service are saints!
I do repairs for people from time to time and have so far have yet to deal with anyone problematic. The day I do I hope it doesn’t sour things because most people Ive encountered in the hobby are patient and respectful.
I've heard this too; it's a job that can start out OK making a few bucks but as soon as you hit an impatient person expecting miracles it can escalate to something far less enjoyable. Similar to eBay buyers - 99% good then you hit the buyer from hell and give up for quite a while. I only offer repairs to friends and they usually supply the parts, coffee or lunch :)
yeah this is something i've mused about. at this point, most "recap" jobs are really "board repair" jobs.
chances are you'll be messing with broken pads, rotten traces, and possibly damaged surface mount components.
this is the type of (expensive) job that in most cases is only viable in very specific industries with irreplaceable hardware... think manufacturing and aerospace.
people always want "professional recap jobs"... but don't want the "professional costs".
Hi I'm in Melbourne; if you have trouble I could re-cap the SE-30 logic board for you.
I've done 6x SE/30s so far they all worked afterwards.
Also done a Classic, Classic II, LCIII and Quadra 605 also all working afterwards. The LCIII even had a cap on backwards from the factory, sheesh!
All have the same bad surface mount electrolytic caps.
I've also tried to build an SE/30 Reloaded (from beyond repair SE/30s) so far without success (simasimac). But I'm determined and haven't given up yet.
The backwards cap on the LCIII is an error on the board screen print. The correct way is opposite to what is shown on the board
Yes, but regardless of the silkscreen one way or the other, to our best understanding, they are all fitted backwards electrically from factory.
If anyone is reading this and about to recap an LCIII.
Use your meter to check which pad has continuity to ground and which to -5v or -12v (whichever it is). Remember - on a negative rail, the +ve side of the capacitor goes to gnd. As confusing as it sounds.
