Got confused by the pin count, all the UE10 pins are now connected correctly and not missing anywhere.
Still Simasima and no sound. Will keep going tomorrow.
is there something off here?
To me Y3 is most likely fine.When I look at the schematic I see both Y3 legs are attached to UE10, Xtal In and Xtal Out. Should both Y3 wave forms be exactly the same, like Y1 is? Does Y3 go bad?
I should've said that I was testing the ROM slot by connecting the scope to the pins themselves, without the ROM in the slot - I'm seeing problems with the wave forms at the pins.I didn't read all your diagnostics, but did you try to tighten the pins of the ROM slot? I’ve already had this issue.
I didn’t have any sound, or chime and simasimac pattern, just like you.I have not tried to tighten the pins, I have wiggled the ROM in the slot and never get any change.
Did you have a chime with loose pins, or ever get it to chime in that condition?
I had heard that just one ROM connection missing will take down the entire system, but I was thinking the chime would still offer a diagnostics in such a scenario.I didn’t have any sound, or chime and simasimac pattern, just like you.
