I’m actually hoping that 2 might lead us to better understanding where the timing data is, potentially enabling the creation of new resolutions as well.Well then for full support of 1600x1200 it sounds like, two routes:
1.) Find a Thunder II GX 1600, get someone to desolder the ROM, dump it, good to go.
2.) Diff the two Thunder IV GX ROMs @Bolle provided to glean the difference and see if we can patch the Thunder II GX 1360 ROM. I'd probably have to do the same and hope my Thunder II non-GX 1360 is HW-wise (except the add-on card).
That might cover 1600x1200, but looks like I have some work to figure out how to get a non-existent 1280x1024 resolution to work.
Since you have the same oscillator speed and memory on your card, I think it’s 100% the same, so hacks should translate.
