Resistors have their values written on them (nnx or nnnx, where n are the start of the value and x is the number of trailing zeros (so 220 is 22 Ohm, not 220 ohm)), so if you beep out the circuit on your pci card you can work out what is connected where, then compare with the personality card and fit the same values in the same places. Where there are gaps, we can compare with iMacs and B&W G3s.
Caps are more tricky because they often aren't labelled. Some will be just isolation caps and we can pick reasonable values, others will need measuring.
