More Video Card probems-Micron Xceed 306
The frequency select signal is pulled high on the card itself through RN10, so you'll only have to connect it to GND or leave it open to select between the two oscillators.
Just for a status update. I've modded the back panel of my Mac SE/30 to accomodate a switch and DB15. I've wired up the DB15 and awaiting the arrival of a connector for the XCEED card. I'm going forward with the advice above for wiring.
Just for clarity, you said pin 12 (CableOK) should go to ground. Does that mean I put a jumper between pin 12 and pin 3 which is supposed to be GND?
Thanks
Thanks
You shouldnt have hijacked this persons thread. Two completely different issues.
