PCB cost for 14cm*12CM... Based on 4-layers, 1.6mm thickness, and... the usual specs.
NOT LEAD FREE. If we want RoHS compliance (only applicable for the final version, and even then I still want to use tin/lead solder) it will be more expensive. I should have mentioned that earlier, but, for the purposes of prototyping, we don't need RoHS compliance. (And not even for the final production version...)
Here we go:
From SEEED:
$118.76 for 10 boards, following the specs above. 5 @ 98.60, 20 @ $159.08
PCBShopper, 10-quantity, same specs as above:
PCBSHopper.pdf
Here we go:
From SEEED:
PCBSHopper.pdf
