Found something interesting: a simple repair for a board with a "blown ADB controller" in the Wikipedia Article on ADB:
Insert usual warning here about info posted on Wikipedia.
One peculiarity of ADB was that in spite of being electrically unsafe for hot-swapping on all but a few machines, it had all of the basic capabilities needed for hot-swapping implemented in its software and support hardware. On practically all original ADB systems it is not safe to plug in or unplug a device once the system is powered on (unlike modern day busses designed with hot-swap in mind). This could cause the opening of a soldered-in fuse on the motherboard. If brought to an authorised dealer this could result in a motherboard swap at a significant expense. A simple alternative was to obtain a fuse at a nominal cost and wire it in parallel across the open motherboard fuse (not even requiring soldering if done appropriately)
