Why Toast names Apple_partition_map 'MRKS'?
butterburger
I observe: in a compact disc published in 1997, its Apple Partition Map is named MRKS.
Partition map (with 512 byte blocks) on 'mike_mulligan.cdr'
#: type name length base
1: Apple_partition_map MRKS 2 @ 1
2: Apple_HFS TOAST 2.5 Partition 325256 @ 317162
Device block size=512, Number of Blocks=642420
(Map is not valid: "With the exception of the driver descriptor record in block 0, every block on a disk must belong to a partition.")
I searched WWW a little while for (Apple_partition_map MRKS), but found no clues. Having read a number of discussions returned by the Web search, it seems many versions of Toast use name 'MRKS', and not only for newly-composed disc projects, but also for copying CD-ROMs.
Does anybody know why MRKS? What, does it stand for software author names, or other abbreviation?
edit: sobbing IP.Board code tag not working
edit: sobbing IP.Board code tag still not working, though it looks good while composing
edit: I so hate IP.Board implementation of bbcode
edit: Why does code tag not work except _while_ using rich AJAX editor? (not in preview nor post)
