So I recently got hold of an image file. There are multiple partitions in the same image. The question now is how can I get this working with an external scs2i2sd (the one that plugs into the back). The file(1) command gives me the output below. How do I configure the scs2sd to get it booted? There is supposedly at least one bootable SSW 7.1 on one of the partitions. Also, on the macs there are internal drives that I'd like to have working along with this. The target macs are one SE FDHD and one SE/30.
Another question is how can I get this going in Basilisk and/or vMac?
Any help greatly appreciated
Mac71.vhd.img:
Apple Driver Map, blocksize 512, blockcount 30934016, devtype 0, devid 0, driver count 1, contains[@0x200]:
Apple Partition Map, map block count 11, start block 1, block count 100, name Apple, type Apple_partition_map, valid, allocated, in use, readable, writable, contains[@0x400]:, contains[@0x600]:
Apple Partition Map, map block count 11, start block 1125, block count 120, name FWB Disk Driver, type Apple_Driver43, processor 68000, valid, allocated, in use, readable, writable, real driver, contains[@0x800]:
Apple Partition Map, map block count 11, start block 1245, block count 4194304, name MacOS, type Apple_HFS, valid, allocated, in use, readable, writable, real driver, contains[@0xA00]:
Apple Partition Map, map block count 11, start block 4195549, block count 4194304, name MacOS, type Apple_HFS, valid, allocated, in use, readable, writable, real driver, contains[@0xC00]:
Apple Partition Map, map block count 11, start block 8389853, block count 4194304, name MacOS, type Apple_HFS, valid, allocated, in use, readable, writable, real driver, contains[@0xE00]:
Apple Partition Map, map block count 11, start block 12584157, block count 4194304, name MacOS, type Apple_HFS, valid, allocated, in use, readable, writable, real driver, contains[@0x1000]:
Apple Partition Map, map block count 11, start block 16778461, block count 4194304, name MacOS, type Apple_HFS, valid, allocated, in use, readable, writable, real driver
Mac71.vhd.img:
