Beware. That is a 1.44M floppy formatted as a 800K floppy by blocking the HD sensor hole on the drive. This makes for flakey unstable disk formats that do fall apart over time. Most 800K drives wont be able to read them, only the drive that created it. It is also a Non-Apple Product. And since it is for the SE and the Plus - it is System 6.04 in the minimum.Thanks for your answer
Macintosh Garden only have System 6 in french...
I think i will buy this : http://www.ebay.com/itm/Startup-System-Disk-for-Macintosh-Plus-SE-all-languages-/272129735505?hash=item3f5c323b51:gNoAAOSwQYZWuwYQ
This seller makes new floppy for only 9$ and in all languages!
Exactly, I have only the manual named "Macintosh Plus" (in French), the first edition, like here : http://earlymacintosh.orgHeres what your looking for,i think
https://68kmla.org/forums/index.php?/gallery/image/785-mac-plus/
Thanks for the link, I will try but I think it will be only in English.If you don't specifically need to buy it, it's here: http://www.rolli.ch/MacPlus/Archives/ZIP/Disk300.zip. And the software bundles should also be here. I've also had an original copy I inherited a long time ago with a Plus that I can image if all of that for some reason doesn't work; links seem to be dropping like hard drives.
That's a problem because many 1.44 disk boxes I have (TDK, Maxell and a couple of others) say on it "Formatted for PC," which means that they were formatted at the factory so the buyer can use them right away, and as probably formatted as a quality test before releasing them. Many such disks I tried to format on Mac OS 1.4 format, and then fail during format but on PC they format fine! But with unformatted 1.44 disks (like Elephant Brand disks) format just fine on the Macs.Well, 1.44 disks that were never formatted, as-in sold originally unformatted, take 800k formats fairly well. The problems usually start if it was used as a 1.44 disk and then someone tried to format it for 800k. Yes, there are inherent track size differences, and there are actual differences in the formation of the magnetic particles on the disk, so the magnetic flux is different, but as long as it was never formatted as 1.44, and one doesn't expect them to last for a decade or more, it should be fine.
If you have time, could you upload it please?I have got SSW 3.2 in French if required (disk images)
