pfuentes69
I got a PowerCache 50MHz (P33) and the adapter made by @Bolle
I tried it with the logic board outside the case, using a cable extender and all works fine. I tried to do benchmarks and I got quite nice improvements.
But... now comes the weird thing... When I try it inside the case, the Mac doesn't boot at all... dead. In a few occasions it boots and resets in cycle, but normally it won't do anything at all.
This happens when I try the PowerCache. Only the accelerator works fine.
I tried to press the card or move it to see if it's a bad contact, but this doesn't seem to be the cause. I also tried to disconnect the Floppy... nothing helps.
Any hint?
Txs!
Any hint?
Txs!
