Mighty Jabba
While browsing eBay on two separate days I found a Mac Plus and a Mac SE that both seemed to have accelerator cards installed. The sellers didn't mention it in either case and seemed to know nothing about it, so it while I didn't pay too much for them, it was a bit of a gamble. Still, I'm kind of fascinated about this kind of modification, so I decided to see what I would end up getting. I'd like to get a little advice about what to do with them. So far, only the Plus has arrived. As you can see, there is a "68030 Power/Total Systems" badge on the front, and a sticker on the back saying that you can't just slide out the logic board as you might normally do, and it also mentions the "Gemini 020/030 card manual" so I'm assuming that the card is called the Gemini from Total Systems. There is also what appears to be a SCSI port in the battery compartment. (I removed a battery that was just starting to corrode.) It came with zero software or accessories beyond the power cable.
The internal floppy appears to be borked in some way -- the mechanism is in the wrong position to receive a disk, and the machine wouldn't even boot from my Floppy EMU while the internal floppy cable was connected. But it did boot just fine when I disconnected it. It shows that it has 4MB of RAM, but in terms of speed, I can't say that it feels any faster than my other Plus, but I haven't done any real tests. It's certainly no speed demon. Opening it up revealed that there was indeed an accelerator board inside.
There is something mounted on top of the floppy drive in a way that makes it necessary to remove everything in order to get at the floppy. I'm pretty reluctant to take everything out just to get at the floppy, but is there anything I could try to fix it with it still installed?
Can anyone tell what is mounted here? I wondered about the possibility of a hard disk, but I think it's some other sort of card.
They also installed a fan.
I'm curious if I'm actually getting any additional speed from the accelerator as it is or not. Worst case scenario, I guess I have a Plus with 4MB of RAM and a SCSI port, so that's pretty cool. Any advice about what I should do regarding the software? Keep in mind that I can only have one thing attached at once (external floppy or the Floppy EMU -- unfortunately I have no SCSI devices but am planning to get an SD2SCSI at some point).
