s_pupp
I could use some advice regarding what steps to take in the following problem:
I have a TiBook G4 1GHz board in a banged-up case that I want to put into a new case (sold as new by Sunshine Express on eBay).
In the old case, both audio channels work. In the new case, only the left channel works; there is no sound at all out of the right channel. Two other logic boards do the same thing in this new case.
Steps taken:
Step 1: Replaced both speakers with known working ones (the logic board connects to the left speaker which then sends a signal to the right, so a problem with the connector on the left speaker could affect the right)
Step 2: Replaced the wire connecting the right speaker to the left speaker with a known working one (although the old one tested OK with my multimeter)
So: It's not the logic board, not the speakers, not the wire connecting the speakers...I'm out of ideas.
With there being no problem at all with all the same equipment in the old case, I'm stuck with the possibility that the case is haunted, and just *&*#ing with me.
I could use a rational mind to convince me otherwise.
Steps taken:
