Kits: | |
$17 | TashTwenty Tiny by @demik, including ribbon cable (supports full-size SD cards, fits in a Hammond case) (OUT OF STOCK - PLEASE LET ME KNOW IF YOU'RE INTERESTED IN THESE BEING RESTOCKED!) |
$17 | TashTwenty Rev 3 by me (smaller, less soldering) |
Optional Extras: | |
$8 | Blue translucent Hammond case for TashTwenty Tiny with custom front and back plates |
$5 | Transcend 4 GB microSD card (known to work, will program with demo image) |
Extra Parts (not necessary if you buy kits): | |
$1.75 | Programmed PIC16F1704 |
$4 | "DB"-19 solder cup connector |
Yes, it would be very nice to be able to hook up an extra floppy drive!Any plans for a passthrough on a future revision?
My first thought was that it come out the opposite end off the back, but now I'm thinking from the top would be easier to route with its current design? Might not be very structurally sound though, unless you plug in the external floppy first, then the Tash20 into the floppy port.Yes, it would be very nice to be able to hook up an extra floppy drive!
Ah, sorry, that's what I meant, by plugging in the floppy drive into the top of the Tash20, then plugging the Tash20 (with the floppy drive already plugged into it from the top) into the floppy port at the back of the Macintosh.Yeah Tash20 needs to be first, otherwise that will not work.
Approvable idea!Yes, it would be very nice to be able to hook up an extra floppy drive!
Kits: | |
$17 | TashTwenty Tiny by @demik, including ribbon cable (supports full-size SD cards, fits in a Hammond case) (OUT OF STOCK) |
$17 | TashTwenty Rev 3 by me (smaller, less soldering) (OUT OF STOCK) |
$4 | "DB"-19 solder cup connector (OUT OF STOCK) |
Hmm. 0x05 indicates that the card entered SPI mode okay and responded to a few commands as normal but blew up when we tried to get it to initialize. It sounds like it could be caused by the issue where the card needs an extra 0xFF clocked out to it before every command, I sent you your kits before I'd made that update to the firmware. How do you feel about picking up (no pun intended) a PICkit3? Thanks to the cost of international shipping, sending you updated PICs would cost almost as much...Any tips for troubleshooting a code of 0x05?
So this is a bit odd...Thanks @tashtari I will look into the pickit3. I just ordered some transcend cards from amazon which should be here tomorrow and Wednesday and I’ll try those first.
That's very strange - no response from the !CS line at all, not even to try to initialize the SD card? My first thought is to try swapping the PICs from one to the other - if the failure follows the board, maybe there's an issue with power; if the failure follows the PIC, then... maybe ESD? It'd be very strange if that were the case, but it's not impossible.the debug line just stayed high the whole time, instead of flashing 0x05 like before or something else.
Small update... I have all the bits, but not the time to upgrade my TT 1.0s to 1805s and latest firmware, but I did do some quick testing on a SE/30 I'm restoring with a ROM-inator ROMSIMM. Works great!Oh, forgot to share... this is my current preferred method of building the original
...the uSD adapter "slung" underneath.
