Trash80toHP_Mini
NIGHT STALKER
I just realized that I don't really have a thread dedicated to this ongoing project, so, in no particular order:
SuperIIsiHack™ related threads:
IIsiColorPivotII_PDS_Card_HackProject™
UNDERClocking a Video Card??????
IIsi PSU: Catastrophic Failure! = 8-o
Switching Mac PSU's @$$tBits + ATX = ????? added 3.3.12
Clean/Prep depopulated board for repopulating?
Compatible solder type for thru-hole . . .
IIfx ROM SIMM in a IIsi . . .
TWO SLOT IIsi Nubus Card hack . . .
IIsiSuperMacPDSadapterRAMhack™
MicroQuadra "Evil Memory Hack" Redux
SuperIIsiHack™ related threads (not mine):
Clocking the IIsi by bibilit
note: I've been working on a compilation of the various idiocies I've undertaken, so I cribbed this list from my War Room scratch pad.
Hack Proposal:
So much arrention has been lavished upon the SE/30 (I lost mine down the storage room whirlpool) for so many years, by so many hackers that I thought I'd buck the trend . . .
. . . if you can imagine such a thing! [
I decided it's time to pay very close attention to the SE/30 and IIci's bastardized, little-loved child. The IIsi has almost every "feature" I abhor in the MacWorld, so I got one off eBay! [
] ]'> The IIsi is Physically Challenged, having far less apparent room/capability for expansion than either parent. I was an intentionally Intellectually Challenged (RAM Bus well and truly Hobbled) Mid-Market-Model with the obligatory level of the Middle-Child' Syndrome, being ignored by Apple and Hacker alike.
Not to forget that is was an intentionally lamed by the provision of an abysmally underpowered PSU to make it incompatible with the Radius Rocket!
I also decided my SuperIIsiHack™ should Kick the @$$ of any SE/30 ever hacked and give the much vaunted Quadra 840AV a run for the money! [}
Specs:
NuBus Treachery:
Minimum Config:
Radius Rocket 33
__Lots of RAM installed on its local bus
__Fast SCSI II DaughterCard on that same local bus/PDS
__Radius Studio Array (Fast SCSI II RAID connected to the PDS SCSI II Daughtercard)
Maximum Hacked Config:
__DuoDock's Gemini Card Hacked onto IIsi NuBus Connection yielding Second NuBus Slot
____LittleRedRadiusPixelRocket™ in lower slot. for NuBus Block Transfer Graphics
Sub-Basement PDS Card Hack:
_____Minimum Config:
________10baseT EtherNet Card
________Radius Color Pivot II/IIsi Video Card (so there will be no Vampire Video detected on startup to mung up the performance of the baseline IIsi/Radius I/O device.
__Maximum Config:
________TWO Radius Color Pivot II/IIsi Video Cards for a possible THREE Monitor Setup
______________This could possibly trump even the IIci's and 840AV's capability when they're paired with the second NuBus Slot/VidCard Hack
Under the Hood:
__Big V-8 Hemi ATX Power Railed goodness!
__a veritable vortex of cooling budget goodness!
. . . and a PseudoSlot ID ROMhack to bind them! }
mode>
Since the Rocket 33 will be blazing as an Accelerator under a lean, mean, tuned up 7.0.1, any Accelerated SE/30, almost any IIci Config and possibly even the 840AV will be left in the dust . . .
. . . and conspicuously missing their doors! :approve:
. . . or so the plan goes! :
Hack Proposal:
Specs:
NuBus Treachery:
Minimum Config:
Radius Rocket 33
__Maximum Config:
Under the Hood:
mode>
