Trash80toHP_Mini
NIGHT STALKER
Can, and will }Personally I think the Compaq Portable III is a nice piece of work / but I don't think I'd have the heart to seriously hack
8-o Now that is gorgeous.
Powerbook G4 12"Duo 2300c is listed on Everymac as:
10.9" x 8.5" x 1.5"
You get that laptop LCDs and cables are not just swap'n'go between models, right?an appropriate display/cable housed within a / donor.
Just how wide are you planning to make this thing?1400's KBD/hacked w/Numeric a/o Function keypad extension
Here, let me standardize that for you:Duo 2300c is listed on Everymac as:
10.9" x 8.5" x 1.5"
Although that specific listing doesn't say so, the seller offers an AV/VGA input board on other panels for an extra $35. His store also conveniently lists all his panels by size, in one inch increments. You may find other candidates there, in the 11" and 12" categories. I looked in the 8" and couldn't find anything over 800x600.Display Area 10.4-inch diagonalNumber of Pixels 1024 × 768
Module Size 236 × 174.3 × 7.4mm
Yep! The one you like is nice, but I'm on a tight budget, for now, and I'm trying to stay within the NetBook/Duo continuum. [] ]'>Still an Atom CPU. But yes, very nice looking. Personally I think I'm in love with the Toshiba Portege A600 I linked above. Core2Duo, mmmmMMmmm
There are a couple rather bad things about this unit.I saw my first 12" (nominal) NetBook today and I'm seriously smitten!
(snip)
According to their pre-sales tech support, it can be upgraded to 2 MB of RAM! :O
They blew the KBD design, it's almost identical to the Duo's. If they had made it almost edge to edge, like their 10.1" model, it would have been almost Full Sized!
When I save up the $ and the "perfect" 12" NetBook is released, I'm going to grab one! [] ]'>
I'll give you just ONE GUESS where HP_Mini is headed right after I set up ubuntu on the 12" Netbook! }
I'm not even considering this unit, it's the screen and its 768 vertical pixels that I love. I'll be waiting until the best of the 12" NetBooks (for running ubuntu) is released and the bugs are worked out before buying one.There are a couple rather bad things about this unit.
I'm looking to keep the weight of the entire bag down to the 5 lb. +- weight of the Duo's carcass. :approve:If you're on a budget really your best choice is to say "screw it" and get a 13 inch "Pentium Dual-Core"/Core Duo 2 machine /... which ironically is still in the same weight class as a Duo anyway.)
I'm confused again... did you like the Asus because of the "whole package" and wanting to use it as such, or just for the screen as part of the mythic Duo hacking exercise? Every "11.6"-inch laptop I saw whilst looking was wider than a Duo 2300c. (11 inches plus, vs the 10.9 of the Duo. That specific Asus is listed as "11.3") Given how skinny the screen bezel is on the Asus the panel is *not* fitting in the Duo lid. Which I suppose means if you were serious about cutting the duo in half and stretching it with an insert you could do it, but... the question "why?" starts seriously raging in ones' ears. There are 10-11.1 inch panels with that resolution that would fit much more easily.I'm not even considering this unit, it's the screen and its 768 vertical pixels that I love. I'll be waiting until the best of the 12" NetBooks (for running ubuntu) is released and the bugs are worked out before buying one.
