Boctor
About a year ago, I cleaned an SE/30 motherboard and recapped it with tantalum capacitors. It has been working normally since then, except for one of the axial capacitors, which was not properly soldered. I got bus errors and sad macs recently, but solved them all by re-soldering the bad joints.
However, problems happen if a PDS card is inserted. In specific, I tried a RasterOps Color Board 264/SE30 and an Asante MacCon 30ie. More confusingly, there was a brief time when the Color Board was working perfectly, but later it began causing the Simasi pattern with the vertical lines. This was the same pattern that I saw when the capacitors went bad, and it is never accompanied by a boot chime of any kind. After a PDS card causes the SE/30 to do this, it still won't start up again, even when the card is removed. What I needed to do was actually remove and reinsert the PRAM battery.
Does anyone know what could be wrong with my PDS slot? Are there any specific capacitors involved that could be messing with it? Thanks for your time, and I apologize if this is a common issue or has been asked before; I couldn't find anything similar with searches.
