SE/30 is ASC a must for booting?
codevonlux
I am working on a new SE/30. The leakage from bad caps must have shorted pin 5/6 of UE10 (ASC sound chip) at some point that caused a serious melt down to UE10. I can even see some mark from black smoke on the bottom of the metal frame that is over the top of UE10.
I removed UE10 and replaced UE8/LS166, replaced all other caps. While waiting for a new sound chip. I want to continue booting the machine. I don’t expect to hear any chime and but is using an oscilloscope to monitor ROM simm A2 pin for activity. I can see ROM was running for like 5 seconds then went to some kind of loop. The pattern of activity matches a long chimes of death.
Is UE10/ASC a must in SE/30 to boot?
-Yi
Arbee
The boot chime code in the ROM polls the ASC state, so you likely won't get visible progress without it.
djc6
Maybe try and send "TechStep" diagnostic commands over the serial port - to see if the CPU is executing code?
Recent video on the topic:
I was able to confirm signs of life on my SE/30 (no video - black screen only) via the serial port.
