bigmessowires
If you've got an SE/30 and the dougg3 ROM SIMM (2MB or 8MB), would you help me test a modified version of the ROM image that I've developed? It works great on my IIsi and IIci, but not on the SE/30. I need help to find whether it's a software or hardware problem. The ROM image is attached. If you've got an 8MB SIMM, you can program this to the first 2MB of your SIMM and leave the rest empty.
Here's what you should get with this ROM image:
- customized startup sound (major 9th arpeggio)
- splash screen at startup displays installed RAM, addressing mode, and rom disk type
- compressed rom disk image containing System 7.1 and some games
- custom happy mac icon (in color!)
- memory test is disabled
- 32-bit clean
- HD20 support
At the splash screen, you can press R or A to boot from the rom disk, or turn it into a writable ram disk (decompresses on the fly, requires 1 MB RAM for decompression cache). Or press X to expand the entire disk image into ram. Or do nothing, and after a few seconds it'll boot from your SCSI drive or any floppy you insert.
On my SE/30, most of this doesn't work, and most of it fails in the same way as the "stock" romdrv0.9.6 from http://synack.net/~bbraun/macromboot.html. So I think either my hardware is bad, or there are serious incompatibilities between the SE/30 and the rom driver that are unrelated to my changes and additions.
- Booting from System 6.0.8 Tools floppy hangs at "Welcome to Macintosh". Occurs with both the BMOW rom image and the romdrv0.9.6 rom image.
- Booting from a Floppy Emu in HD20 mode (containing System 6.0. also hangs at "Welcome to Macintosh". Occurs with both the BMOW rom image and the romdrv0.9.6 rom image.
- Pressing R, A, or X at the splash screen hangs. (with BMOW rom)
- Holding R during startup boots successfully from the rom disk (with romdrv0.9.6)
FYI this rom image should also work on any of the other Macs that are compatible with the dougg3 simm, so feel free to try it. But it's specifically the SE/30 that I need some help with. Thanks!
2MB-fc2.zip
- 32-bit clean
- HD20 support
2MB-fc2.zip
