They are. I was just looking at it with ResEdit. Not sure if you'd be limited to swapping out what's in there now or if it would be possible to add additional icons to choose from.You can do that with I believe 7 and later...but under 6 (which most systems that have my SCSI2SDs run) you cannot. I am sure if I was ambitious, those icons are just resources I could swap out with ResEdit.
This is exactly what I had to do to get these to get to a point where I could install the OS onto the SD cards I bought for my IIsi's. I needed a bootable System 6.08 disk, LIDO, and the case on the IIsi open with the USB cable attached to the SCSI2SD board and the IIsi powered by its conventional power source (i.e. plugged into the wall). LIDO was necessary for setting up the virtual hard drives, but it could not see them unless the SCSI2SD board was powered by the USB cable. I also had a peculiar issue where I could not install OS 7.1 unless I had 6.08 on the hard drive first. I did that by dragging the disk image from the bootable floppy to the virtual drive at SCSI ID 0, then booting the IIsi up from that, and installing System 7.1 over the top using a set of install disks. For some reason, If I tried to just install 7.1 onto a bare drive, it wouldn't boot. Weird, but that's how it went. I also found that in my IIsi's, I absolutely MUST use the molex to floppy style connector to power the SCSI2SD board once all of the software issues are straightened out. Neither of the IIsi's would boot if I tried to use only the SCSI cable for power. I am not having that problem with the g3 I am currently working on. The SCSI cable supplies enough power in it.Providing power through the USB connection seems to be a common fix.
Blaming SCSI2SD for "issues" when _you_ have configured termination on your SCSI bus incorrectly is absurd. You have to have termination configured properly, regardless of the type/manufacturer of SCSI devices you choose to use. SCSI termination is _simple_ You must have termination at the END(s) of your SCSI chains, period. Not in the middle, not double-terminated. If you do anything but that, you can and SHOULD expect problems, as it's electrically incorrect, per the SCSI specification.@maceffects what version SCSI2SD devices do you have? I have had major issues (as evidenced above) but made some progress recently.
I have two 5.0a versions and those are a major problem. One of them had somewhat old firmware on it, but even with updating, I've had nothing but issues with that model; they don't show up AT ALL anymore on the SE/30.
I switched to two 5.1 versions (trying to copy from one to the other) and those are better. But I still had an issue (termination conflict) with both of them terminated via the SW utility setup and one on the external SCSI bus powered. When I removed the power from the external one, then they both worked fine.
There are zero details in this post. How was your SCSI2SD configured? Volume size? Was it the only device on the bus? Was it installed internally? Was termination enabled? Which utility did you attempt to use to partition your SCSI2SD? Which version of System?So I bought 5 SCSI2SD boards and have had major issues getting them to work. I am trying on 3 different SE/30 machines. I followed the instructions on how to flash it to work with Macs, but when installed in an SE/30 it doesn't show up (using Apple Drive software and Lido). They do sometimes produce a steady but slow flash of the activity LED light. Am I missing something?
I asked a number of specific questions above, but you've not answered several of them. This is not helpful. Specifically, Which utility did you attempt to use to partition your SCSI2SD? Which version of System? The config you posted the above screenshot of won't work, nor is expected to work, with the original, un-patched Apple disk formatting utility. Third party utilities such as Lido and FWB Hard Disk toolkit should be able to partition SCSI drives which aren't configured with the necessary Apple-approved vendor strings.@aperezbios 1.99gb, and the SCSI termination was proper for the SE/30 machines. No other devices on the SCSI bus. Attached is a photo showing exactly what I put in. Sorry the text is white, I have no idea why that is. Its easier to read in person.
The current situation:I asked a number of specific questions above, but you've not answered several of them. This is not helpful. Specifically, Which utility did you attempt to use to partition your SCSI2SD? Which version of System? The config you posted the above screenshot of won't work, nor is expected to work, with the Apple disk formatting utility. Third party utilities such as Lido and FWB Hard Disk toolkit should be able to partition SCSI drives which aren't configured with the necessary Apple-approved vendor strings.
I now have one more question for you, regarding SCSI2SD-util...in the screenshot posted above, at the bottom of the window, it says 'save failed', so are you certain that this config is what's actually written to your SCSI2SD board? Do you know which version(s) of firmware are on your SCSI2SD?
The attached scsi2sd-util configuration file can be opened in SCSI2SD-util, then saved to your board. It configures your SCSI2SD as per the instructions in this thread:
Okay, good. And, to confirm, both of these ribbon cables are _known working_? They are known to work with normal hard drives?I've tried 2 different ribbons, one that was standard and one that was longer (made for plug in and out easier). You are right, I changed the settings to normal rather than Dark Mode and it resolved the textual display issue.
