N8VEM HBIOS v2.2 B3 (S2I-WWarthen-130130T0838)
SCSI2IDE, PPIDE (STD), SD CARD
Zapple V1.1
>G1000
S2I Target Command Processor (press a key to terminate)
*** Bus Free ***
[start of host controller enumerating SCSI bus at BIOS initialization]
[Cmd=00, TEST UNIT READY, looks OK]
Select Wait: 00:08:00 80:18:A2 00:18:A2 01:18:00 00:18:6B 03:1A:41
Message Out: 80
Command: 00 00 00 00 00 00
Status: 00.
Message In: 00.
*** Bus Free ***
[Cmd=12, INQUIRY, looks OK]
Select Wait: 03:1A:41
Message Out: 80
Command: 12 00 00 00 02 00
Data In: 00 00 .
Status: 00.
Message In: 00.
*** Bus Free ***
[DOS 6.22 bootup starts here]
Select Wait: 03:1A:42 00:18:00 03:1A:44 00:18:00 03:1A:48 00:18:00 03:1A:50 00:1
8:00 03:1A:60 00:18:00 03:1A:C0 00:18:00 03:1A:41
Message Out: 80
Status: 00.
Message In: 00.
*** Bus Free ***
Message Out: 80
Command: 12 00 00 00 24 00
Data In: 00 00 01 01 20 00 00 00 4E 38 56 45 4D 20 20 20 .
Status: 00.
Message In: 00.
*** Bus Free ***
[Cmd=25, READ CAPACITY, looks OK]
Message Out: 80
Command: 25 00 00 00 00 00 00 00 00 00
Data In: 00 00 A0 00 00 00 02 00 .
Status: 00.
Message In: 00.
*** Bus Free ***
[Cmd=08, READ, LBA=0 for 1 block, looks OK]
Select Wait: 01:18:00 03:1A:42 00:18:00 03:1A:44 00:18:00 03:1A:48 00:18:00 03:1
A:50 00:18:00 03:1A:60 00:18:00 03:1A:C0 00:18:00 40:18:40 03:1A:41
Message Out: 80
Command: 08 00 00 00 01 00
SD: 40 00 00 00 00 95 --> RC=01 TOK=00
SD: 48 00 00 01 AA 87 --> RC=05 TOK=00
SD: 77 00 00 00 00 FF --> RC=01 TOK=00
SD: 69 40 00 00 00 FF --> RC=01 TOK=00
SD: 69 40 00 00 00 FF --> RC=00 TOK=00
SD: 7A 00 00 00 00 FF --> RC=00 TOK=00
SD: 50 00 00 02 00 FF --> RC=00 TOK=00
SD CARD TYPE: 02
SD: 51 00 00 00 00 FF --> RC=00 TOK=00
Data In: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .
Status: 00.
Message In: 00.
*** Bus Free ***
[Cmd=08, READ, LBA=0 for 1 block, looks OK, but repeat of previous read, not sure why]
Message Out: 80
Status: 00.
Message In: 00.
*** Bus Free ***
[DOS 6.22 FDISK startup begins here]
Message Out: 80
Status: 00.
Message In: 00.
*** Bus Free ***
Select Wait: 01:18:00 00:18:00 03:1A:41
Message Out: 80
Status: 00.
Message In: 00.
*** Bus Free ***
[At this point, I select the FDISK option to create a new primary partition]
Message Out: 80
Status: 00.
Message In: 00.
*** Bus Free ***
[Cmd=08, READ, LBA=0x11 for 0x11 blocks, looks OK]
Select Wait: 01:18:00 40:18:40 03:1A:41
Message Out: 80
Command: 08 00 00 11 11 00
SD: 51 00 00 22 00 FF --> RC=00 TOK=00
SD: 51 00 00 24 00 FF --> RC=00 TOK=00
SD: 51 00 00 26 00 FF --> RC=00 TOK=00
SD: 51 00 00 28 00 FF --> RC=00 TOK=00
SD: 51 00 00 2A 00 FF --> RC=00 TOK=00
SD: 51 00 00 2C 00 FF --> RC=00 TOK=00
SD: 51 00 00 2E 00 FF --> RC=00 TOK=00
SD: 51 00 00 30 00 FF --> RC=00 TOK=00
SD: 51 00 00 32 00 FF --> RC=00 TOK=00
SD: 51 00 00 34 00 FF --> RC=00 TOK=00
SD: 51 00 00 36 00 FF --> RC=00 TOK=00
SD: 51 00 00 38 00 FF --> RC=00 TOK=00
SD: 51 00 00 3A 00 FF --> RC=00 TOK=00
SD: 51 00 00 3C 00 FF --> RC=00 TOK=00
SD: 51 00 00 3E 00 FF --> RC=00 TOK=00
SD: 51 00 00 40 00 FF --> RC=00 TOK=00
SD: 51 00 00 42 00 FF --> RC=00 TOK=00
Status: 00.
Message In: 00.
*** Bus Free ***
[Cmd=0A, WRITE, LBA=0x11 for 1 block, looks OK]
Message Out: 80
Command: 0A 00 00 11 01 00
Data Out: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SD: 58 00 00 22 00 FF --> RC=00 TOK=00
Status: 00.
Message In: 00.
*** Bus Free ***
[Cmd=08, READ, LBA=0x22 for 0x100 blocks
This is where things go wrong. First of all, even though
a read block count of 0 is explicitly defined to mean
read 256 blocks by all the specs, I have trouble believing
this is really what is intended. DOS 3.3 FDISK does not
do this. As you will see below, the S2I firmware does as
I intend for it to: it starts reading and transferring
256 blocks of data. However, after doing exactly 128
blocks, the host/initiator refuses to take any more data.]
Message Out: 80
Command: 08 00 00 22 00 00
SD: 51 00 00 44 00 FF --> RC=00 TOK=00
SD: 51 00 00 46 00 FF --> RC=00 TOK=00
SD: 51 00 00 48 00 FF --> RC=00 TOK=00
SD: 51 00 00 4A 00 FF --> RC=00 TOK=00
SD: 51 00 00 4C 00 FF --> RC=00 TOK=00
SD: 51 00 00 4E 00 FF --> RC=00 TOK=00
SD: 51 00 00 50 00 FF --> RC=00 TOK=00
SD: 51 00 00 52 00 FF --> RC=00 TOK=00
SD: 51 00 00 54 00 FF --> RC=00 TOK=00
SD: 51 00 00 56 00 FF --> RC=00 TOK=00
SD: 51 00 00 58 00 FF --> RC=00 TOK=00
SD: 51 00 00 5A 00 FF --> RC=00 TOK=00
SD: 51 00 00 5C 00 FF --> RC=00 TOK=00
SD: 51 00 00 5E 00 FF --> RC=00 TOK=00
SD: 51 00 00 60 00 FF --> RC=00 TOK=00
SD: 51 00 00 62 00 FF --> RC=00 TOK=00
SD: 51 00 00 64 00 FF --> RC=00 TOK=00
SD: 51 00 00 66 00 FF --> RC=00 TOK=00
SD: 51 00 00 68 00 FF --> RC=00 TOK=00
SD: 51 00 00 6A 00 FF --> RC=00 TOK=00
SD: 51 00 00 6C 00 FF --> RC=00 TOK=00
SD: 51 00 00 6E 00 FF --> RC=00 TOK=00
SD: 51 00 00 70 00 FF --> RC=00 TOK=00
SD: 51 00 00 72 00 FF --> RC=00 TOK=00
SD: 51 00 00 74 00 FF --> RC=00 TOK=00
SD: 51 00 00 76 00 FF --> RC=00 TOK=00
SD: 51 00 00 78 00 FF --> RC=00 TOK=00
SD: 51 00 00 7A 00 FF --> RC=00 TOK=00
SD: 51 00 00 7C 00 FF --> RC=00 TOK=00
SD: 51 00 00 7E 00 FF --> RC=00 TOK=00
SD: 51 00 00 80 00 FF --> RC=00 TOK=00
SD: 51 00 00 82 00 FF --> RC=00 TOK=00
SD: 51 00 00 84 00 FF --> RC=00 TOK=00
SD: 51 00 00 86 00 FF --> RC=00 TOK=00
SD: 51 00 00 88 00 FF --> RC=00 TOK=00
SD: 51 00 00 8A 00 FF --> RC=00 TOK=00
SD: 51 00 00 8C 00 FF --> RC=00 TOK=00
SD: 51 00 00 8E 00 FF --> RC=00 TOK=00
SD: 51 00 00 90 00 FF --> RC=00 TOK=00
SD: 51 00 00 92 00 FF --> RC=00 TOK=00
SD: 51 00 00 94 00 FF --> RC=00 TOK=00
SD: 51 00 00 96 00 FF --> RC=00 TOK=00
SD: 51 00 00 98 00 FF --> RC=00 TOK=00
SD: 51 00 00 9A 00 FF --> RC=00 TOK=00
SD: 51 00 00 9C 00 FF --> RC=00 TOK=00
SD: 51 00 00 9E 00 FF --> RC=00 TOK=00
SD: 51 00 00 A0 00 FF --> RC=00 TOK=00
SD: 51 00 00 A2 00 FF --> RC=00 TOK=00
SD: 51 00 00 A4 00 FF --> RC=00 TOK=00
SD: 51 00 00 A6 00 FF --> RC=00 TOK=00
SD: 51 00 00 A8 00 FF --> RC=00 TOK=00
SD: 51 00 00 AA 00 FF --> RC=00 TOK=00
SD: 51 00 00 AC 00 FF --> RC=00 TOK=00
SD: 51 00 00 AE 00 FF --> RC=00 TOK=00
SD: 51 00 00 B0 00 FF --> RC=00 TOK=00
SD: 51 00 00 B2 00 FF --> RC=00 TOK=00
SD: 51 00 00 B4 00 FF --> RC=00 TOK=00
SD: 51 00 00 B6 00 FF --> RC=00 TOK=00
SD: 51 00 00 B8 00 FF --> RC=00 TOK=00
SD: 51 00 00 BA 00 FF --> RC=00 TOK=00
SD: 51 00 00 BC 00 FF --> RC=00 TOK=00
SD: 51 00 00 BE 00 FF --> RC=00 TOK=00
SD: 51 00 00 C0 00 FF --> RC=00 TOK=00
SD: 51 00 00 C2 00 FF --> RC=00 TOK=00
SD: 51 00 00 C4 00 FF --> RC=00 TOK=00
SD: 51 00 00 C6 00 FF --> RC=00 TOK=00
SD: 51 00 00 C8 00 FF --> RC=00 TOK=00
SD: 51 00 00 CA 00 FF --> RC=00 TOK=00
SD: 51 00 00 CC 00 FF --> RC=00 TOK=00
SD: 51 00 00 CE 00 FF --> RC=00 TOK=00
SD: 51 00 00 D0 00 FF --> RC=00 TOK=00
SD: 51 00 00 D2 00 FF --> RC=00 TOK=00
SD: 51 00 00 D4 00 FF --> RC=00 TOK=00
SD: 51 00 00 D6 00 FF --> RC=00 TOK=00
SD: 51 00 00 D8 00 FF --> RC=00 TOK=00
SD: 51 00 00 DA 00 FF --> RC=00 TOK=00
SD: 51 00 00 DC 00 FF --> RC=00 TOK=00
SD: 51 00 00 DE 00 FF --> RC=00 TOK=00
SD: 51 00 00 E0 00 FF --> RC=00 TOK=00
SD: 51 00 00 E2 00 FF --> RC=00 TOK=00
SD: 51 00 00 E4 00 FF --> RC=00 TOK=00
SD: 51 00 00 E6 00 FF --> RC=00 TOK=00
SD: 51 00 00 E8 00 FF --> RC=00 TOK=00
SD: 51 00 00 EA 00 FF --> RC=00 TOK=00
SD: 51 00 00 EC 00 FF --> RC=00 TOK=00
SD: 51 00 00 EE 00 FF --> RC=00 TOK=00
SD: 51 00 00 F0 00 FF --> RC=00 TOK=00
SD: 51 00 00 F2 00 FF --> RC=00 TOK=00
SD: 51 00 00 F4 00 FF --> RC=00 TOK=00
SD: 51 00 00 F6 00 FF --> RC=00 TOK=00
SD: 51 00 00 F8 00 FF --> RC=00 TOK=00
SD: 51 00 00 FA 00 FF --> RC=00 TOK=00
SD: 51 00 00 FC 00 FF --> RC=00 TOK=00
SD: 51 00 00 FE 00 FF --> RC=00 TOK=00
SD: 51 00 01 00 00 FF --> RC=00 TOK=00
SD: 51 00 01 02 00 FF --> RC=00 TOK=00
SD: 51 00 01 04 00 FF --> RC=00 TOK=00
SD: 51 00 01 06 00 FF --> RC=00 TOK=00
SD: 51 00 01 08 00 FF --> RC=00 TOK=00
SD: 51 00 01 0A 00 FF --> RC=00 TOK=00
SD: 51 00 01 0C 00 FF --> RC=00 TOK=00
SD: 51 00 01 0E 00 FF --> RC=00 TOK=00
SD: 51 00 01 10 00 FF --> RC=00 TOK=00
SD: 51 00 01 12 00 FF --> RC=00 TOK=00
SD: 51 00 01 14 00 FF --> RC=00 TOK=00
SD: 51 00 01 16 00 FF --> RC=00 TOK=00
SD: 51 00 01 18 00 FF --> RC=00 TOK=00
SD: 51 00 01 1A 00 FF --> RC=00 TOK=00
SD: 51 00 01 1C 00 FF --> RC=00 TOK=00
SD: 51 00 01 1E 00 FF --> RC=00 TOK=00
SD: 51 00 01 20 00 FF --> RC=00 TOK=00
SD: 51 00 01 22 00 FF --> RC=00 TOK=00
SD: 51 00 01 24 00 FF --> RC=00 TOK=00
SD: 51 00 01 26 00 FF --> RC=00 TOK=00
SD: 51 00 01 28 00 FF --> RC=00 TOK=00
SD: 51 00 01 2A 00 FF --> RC=00 TOK=00
SD: 51 00 01 2C 00 FF --> RC=00 TOK=00
SD: 51 00 01 2E 00 FF --> RC=00 TOK=00
SD: 51 00 01 30 00 FF --> RC=00 TOK=00
SD: 51 00 01 32 00 FF --> RC=00 TOK=00
SD: 51 00 01 34 00 FF --> RC=00 TOK=00
SD: 51 00 01 36 00 FF --> RC=00 TOK=00
SD: 51 00 01 38 00 FF --> RC=00 TOK=00
SD: 51 00 01 3A 00 FF --> RC=00 TOK=00
SD: 51 00 01 3C 00 FF --> RC=00 TOK=00
SD: 51 00 01 3E 00 FF --> RC=00 TOK=00
SD: 51 00 01 40 00 FF --> RC=00 TOK=00
SD: 51 00 01 42 00 FF --> RC=00 TOK=00
SD: 51 00 01 44 00 FF --> RC=00 TOK=00
[At this point, everything is hung. Exactly 128 sectors have been transferred.
S2I is waiting for ACK to be asserted by the initiator, but it never happens.
Essentially, the initiator has decided to stop consuming data. FDISK is unresponsive.]
