Hi,
Is anyone interested in building or buying a homebrew SCSI-to-SD card adaptor ?
I have developed such a device which is already capable of booting and running
OS 7.5.3 on the old pizza-box macs. It also works as a normal SCSI-2 device
under Linux as well, so it should work on most platforms.
I'll be putting in a PCB order this week for the "final" version, and I can
order extra if others are interested. I haven't actually tested this version
of the PCB, but there are only small changes to the SCSI and SD interfaces
compared to the working prototype version.
I could supply bare PCB's for cost price (about $3 each plus shipping), or
completed boards for $45 AUD + shipping.
To build your own requires surface mount soldering and an expensive Cypress
Miniprog3 programmer. It's probably compatible with other SWD programmers via a
suitable adaptor, but no guarantees.
Full schematics, pcb layouts, and source code is available at the project page:
http://www.codesrc.com/mediawiki/index.php?title=SCSI2SD
Note that the source code is a little bit out-of-date, and will be updated to
support the current pinout and firmware updates over USB at the very minimum
before I would mail any PCBs.
I'll be testing out a 3d printed bracket this weekend, which will allow mounting
the device in a standard 3.5" hard disk bay. It's already printed, I just need
to see if I can tap some screw holes into the plastic.
The device uses a Cypress PSoC 5lp microcontroller to bit-bang the SCSI
interface. At some point I'll try to make use of the programmable logic
aspects of the PSoC to speed up the SCSI interface.
