aperezbios
@Brooklyn It sounds like one or more of your ZuluSCSI boards may be operating in "raw passthrough" mode. If that's the case, the LED on the ZuluSCSI will blink three times upon initialization (to indicate it didn't find a valid image file OR filesystem).
Currently, the only way to change the SCSI ID on a board that's using raw passthrough mode is at compile time. You could, however, create an image of the existing SD card, using something like win32diskimager, or, any other raw disk read utility, and then name that file HDn.xyz, where N is the SCSI ID you desire.
