ROM Simm Programmer
dougg3
I think I just figured out the commands not working properly too. How strange. Here's a test build of programmer software 2.0 with fixes for Windows 7. Just extract SIMMProgrammer2.0-win.zip, and replace its SIMMProgrammer.exe with this one.
  • SIMMProgrammer2.0-win7fix.zip
ymk
The update works. It found the programmer immediately.
Reading and writing works. A read-back diff checks out, but my SE/30 won't boot from the 1.2mm SIMM. Probably a contact issue.
Thanks for the very quick fix!
dougg3
You’re welcome! I will look into releasing it as a new version 2.0.1 eventually.
Yeah, definitely sounds like a contact issue. The SE/30 sockets have always been flaky. I wish the PCB manufacturers had standardized on 1.27mm.
