amatecha
Check it out.. retr0bright progress on my SE/30 .. just doing the rear case so far.
That's with just about 2 hours of sunlight in the evening, and then having it under a black light overnight. Not bad at all! Another afternoon should finish it off! Totally excited to have it side-by-side with the front just to see the difference!
For comparison purposes, notice the rectangular gray square on the front... that's the original color as far as I can tell. There was a sticker over that corner!
