Maconthemove
Another possibility is the Daystar Quad 040 running at 40 MHz with a 128k SRAM cache, It fits into the PDS slot.
I think we discussed that in another thread. At that time, we agreed that the PDS slot in the Q660av was not a real PDS slot...The 840av and 660av have no PDS slot for upgrades. I also think the AV section and DSP are probably tied to the CPU clock so messing with that will probably cause problems.
So, yes, the PDS slot in the 660av is a full-fledged 040 PDS.The Macintosh Centris 660AV (but not the Macintosh Quadra 840AV) can accept an accessory card that plugs directly into the main circuit board instead of into the adapter card shown in Figure 2-13. An accessory card plugged into the main circuit board can gain access to the processor as well as to the DAV bus. The resulting processor-direct slot (PDS) capability is similar to that of the Macintosh Centris 610 computer, described in the Macintosh Centris 610 Developer Note.
The Macintosh Centris 610 computer uses an AMP type 650231-5 connector for PDS cards; the Macintosh Centris 660AV uses an AMP type 650231-3 connector. Because the corresponding pins are aligned, it is possible to design PDS cards that work on both models.
CPU sockets are compatible (not the PDS though) BUT the upgrades won't necessarily physically fit in the case. I once tried to install a Quadra 650 Quaddoubler in a Quadra 660av. Didn't work because it was overlapping the CD drive tray.Any reason why you couldn't use a CPU socket upgrade for a Centris 650 in a 660? They both run a 25MHz native CPU
