BadGoldEagle
Hi all,
I've got a Quicksilver in the mail. Should arrive in about two weeks. It has a 1.7GHz Sonnet Encore ST, a bunch of cards (Firewire 800, USB2.0, Radeon 9000) and no airport card. Since that mac was in Basel Switzerland, ArmorAlley agreed to act as an intermediary. I'll also be getting a SATA card from him. Might as well kill two birds with one stone, right?
Money shot:
That's not the only upgrade I plan on adding to this PM though.
I'd like to upgrade the GPU to a 7800GS. I know that requires a ROM flash and a couple other things but at least I'll be able to play 2003 games on High with a more than adequate framerate. Apparently it is also somewhat OS9 compatible. You can't control it properly but it *works*. Does anybody here use this card in their G4? I intend to install Leopard on this machine, but there are a couple of games that require OS9 (namely Tomb Raider I and II). I'll either install OS9 on a second partition or Sheepshaver in order to play those games. Sheepshaver for PPCs seems to work quite well, but doesn't emulate or use (AFAIK) GPU 3D acceleration. TRI and TRII don't really need a GPU in the first place but what do you guys recommend? I could get a PCI card and use it exclusively for OS9 but I'd be left with only 3 PCI slots...
I'd rather not install OS9, because 1) It'll take quite a bit of space on my disk, 2) The 7800GS might prove to be too incompatible with it and 3) See below...
I'll connect this mac to a television via HDMI (I already have a DVI to hdmi adapter), so I'll sit on the couch about 10ft away from the mac. For this reason I'm planning on getting wireless Apple peripherals (and a PS3 controller, but more on that later). I could get an Airport card which does bluetooth, but is limited to 802.11b. I know there are PCI alternatives, but which ones are the best? I'd like to maintain OS9 compatibility, just in case I change my mind afterwards...
Next, I'd like to get a SCSI card for a Zip/Jaz drive I might add later to the collection. Any Mac compatible card should do the job nicely without any issues, although I've heard that some controllers aren't compatible with some accelerators...*
Finally, I'll probably replace the two usb and firewire cards with a Sonnet Tango 2.0 because onboard firewire doesn't work and I'll quickly run out of PCI slots.
So yeah, my ideal setup would have the following cards: Sonnet Encore, Sonnet Tempo, Sonnet Tango, ATTO SCSI, Wifi/Bluetooth card and of course the 7800GS.
Anything particular I should look into before getting all those additional cards?
Money shot:
