So I might have found a possible soloution as I have now reapried all three of my broken 80 meg Quantum ELS Prodrives; to fully working condition again. This is by no means a professional repair but more of a jimmy rig which you have to do to fix lol. But I figured I was not taking a loss since they were all busted in the first place.
I watched what it was doing and I am assuming here, but it looks as if the head parks too close to the platters spindle thus, no information is stored this close to the spindle so its doing nothing but spinning up and back down. So I thought up this little rig and its now worked on all three busted HDD's that just spin up and back down again.
I exposed the part of the drive I was working on only, and started by removing the top magnet motor housing covering the arm's coil. First remove the nut in the top middle; then the two philips screws holding the plate on.
Then I removed the top motor magnet plate using the precission set flat blade, and a pliers in the middle once lifted. Carefully lift with pliers and make sure not to hook the plate up on the middle nut threads.
I then had some un-used disposable foam air stones for a fish tank that were already round in shape, and about the right size to fit in the housing structure. I cut the foam air stone with a blade to what I thought looked like the right height, making sure I left it a bit longer so the pressure of the top plate screwed down will hold it in place. This gives me the foam ring I need to make this HDD work again. Making it too small will cause the foam ring to move around and possiably moving out onto the platter thus, trashing your HDD, so make sure you cut it longer in length. I then placed the foam ring in the lower right side of the arm's motor structure.
Then put the top magnet plate back on and screwed the philips in first, and finger tighten the nut.
Now, I took the small flat blade screw driver and wedged it between the top and bottom plate carefully and pressed in on the foam ring turning it into more of a "U" shape. Do the same on the opposite side pressing in gently on the foam ring. Dont break the ring by pressing too hard.
Now your ready to test the drive out. Hook it up and fire it up. Listen for it to spin up and start booting. If it does, turn off the machine, wait for it to spin down and do it again just to test. If you hear any weird noises turn it off immediatly. I had this happen to me the first time and it was because I did not press the foam ring into a U good enough. Most likley that is your issue if it makes weird noises. If the drive stays spun up you just fixed your Quantum Prodrive ELS. THese HDD's are pretty robust, seem they can take alot lol. All three of mine worked as if they were never broken. None even needed to be re loaded or re formated. They all are working just as good as they were when last working.
Hope this helps someone else.
Nick.
