Johnnya101
I am sending my Q700 PSU off to get recapped. The computer turns on just fine, bongs, green lights, etc. Runs quiet, very quiet fan. But it wont shut off! You press the power button, and it turns right back on. If you unplug it and plug it back in, it does not start automatically, you must hit the power key (Which is correct).
I know these power supplies are pretty much junk anyways, in regards to caps. I think this is a simple cap issue. Is there anything else the recapper should look for?
This is the more uncommon GE power supply, not Astec.
