PowerMac 7600/120 plus monitor
macgreg
Picked up from eBay locally for the princely sum of 99c.
The monitor is an AppleVision 1710. I will check the specs out tonight but the 7600 looks pretty stock.
macman142
Nice work Greg. Can't go wrong for 99c - did you hand over the $1 coin??
Those AV 1710's are nice screens (when they work). I've had 4, and 3 of them have been stuffed!!!
I've probably got some memory here if you need some extra?
macgreg
I actually gave the guy $4 - what I had in the change compartment of the car. He did help me load it into the car.
The specs of the 7600 are 120MHz 604/64MB RAM/2GB HDD. The AV 1710 works well and is currently being used on the 7500/G3.
Thanks for the RAM offer - I'll let you know :)
