mraroid
Folks...
I was looking up the Panasonic battery that was the original PRAM battery in my
Powerbook A1095 M9422LL/A. It was made by Panasonic and it's model number is CGL3032. I could not find it any place. But I did learn the specs on it. It is 3.2mm thick and is 140mAh, 3.7 volts and is a Li ion battery.
After a lot of digging around, I found a replacement battery. It is called LIR3032. But in my searching, I found yet another battery that is the same size and spec as the original, but it is rated at 200mAh. It even comes with solder tabs to make it really easy to swap out your old PRAM battery. I have not found a good price for this battery, but here is an example:
http://www.ebay.com/itm/300990106311
I can see no reason to buy the replacement board along with a PRAM battery. I think I would rather buy a fresh 200mAh battery and solder it into my PRAM board whne I remove the dead battery.
Anyone know of a cheaper source of the above battery? It is a tad high at $20.
jack
jack
