I have a question about charging my PowerBook.
My the connector for the charger for my Titanium PowerBook G4 is very flakey. To charge my PowerBook, I have to twist it into the right orientation and apply slight pressure to one side (very slight, not enough to damage the computer). I don't believe that the laptop is the issue, since I have the same issue with my other G4, and the charger is a random knockoff brand.
My question is: can I use the charger for a PowerBook Duo 230 on this laptop? I've compared it to my yoyo-style charger (dead), and the voltages are the same, and the connectors appear to be the same, with the only difference being the G4 adapter supplies 1.875 amps, whereas the Duo charger supplies only about 1.04 amps (I'd have to dig it out for the exact number...). Will I damage anything, or will the only issue be that the laptop charges more slowly?
Would this work for a 17" Aluminum PowerBook, too? I'd expect they require a significantly greater amount of power. This working is less important; as I care mostly about the TiBook.
Thanks
Thanks
