Zippy Zapp
I bought a PowerBook G3 WallStreet model a while back that appears to be the first revision 233mhz with the lame zero L2 cache. It came with 2 floppy modules installed and no battery or optical drive. I got a new in box CD module for next to nothing but I have been unable to find a battery. Does anyone know of any replacements, aftermarket, etc? I can live without it but it would be nice to have.
The PRAM battery is dead and unlike my TiBook G4 that is 2 years newer it won't charge the PRAM battery even after being plugged in for a week now. Oh well, not critical I guess. I can probably shoehorn some other cells that are the same voltage and Lithium rechargeable in there as the cells they used are quite pricey. If I had a battery pack then that would be unnecessary anyway.
As for the gimped no cache 233mhz is it possible to install a CPU card from the 266 or 300mhz PDQ, which was the next revision of WallStreet? I have read that they work but I didn't want to try it for fear of frying the logic board or something. Has anyone any information on this or tried it? I believe there were also aftermarket CPU upgrades but I am sure those are pretty rare and pricey.
None of these things are crucial but I do know the CPU upgrade with cache would be a decent boost as I have seen the difference in two models with and without.
Overall this is a great machine and I think I prefer these over the Ti G4's.
