I believe the case uses regular philips screws but you will need a set of hex drivers too, cant remember what sizes.
Remove all those rubber bits in the picture, remove the screws under them, I used a very small flat head screwdriver to pry out the rubber protectors but im not sure it was the best idea. Make sure the rubber bits are all stored in a container right after removing, I lost 2 of the top rubber bits. I used a plastic prying tool to go all the way around the lid except for the large hinge at the bottom and then I removed the plastic cover. I remember there were screws holding the screen in and other screws for the screen bracket. Some dont need to be removed, cant remember which. The connector for the backlight unfortunately doesn't unplug by removing just the LCD enclosure in the lombard, it appears that the connector runs through the screen into the logic board chassis in mine. I snipped both the new LCD backlight wires and old ones, there were two connectors, a thicker one and thinner one in both old and new wires, i connected thickest to thickest and both thinner ones and it worked, absolutely made sure both wires were insulated properly with electrical tape but should of used shrink wrap too.
Be careful if you follow what I said, I dont know if its the best idea, proper replacement documentation may exist somewhere, you may be able to connect the new backlight wire to the correct socket without cutting both ends and soldering old and new together, im sure I voided my LCD warranty with what I did.
