jmacz
Googling for “104 thermistor” shows that would designate a thermistor with 100k ohm resistance at 25C, and you should be able to measure your existing one to get the dimensions for a replacement. The tricky part is figuring out the B value of the original, which describes the curve for how the resistance changes as the temperature changes.
Yeah, and I still don't know if it's even bad or whether I'm barking up the wrong tree. Did not dawn on me that it was a thermistor as the ones I had seen previously look more blobby capacitors than SMD resistors. Learn something new.
The OS clearly thinks the battery gets fully charged, I've tried a few battery utilities as well as the battery DA included in System 7.1.1, and all report 100% charge, and the battery tools that report voltage, show a reading around 7.1V when it reaches 100%. Yet, then running Battery Amnesia, it starts at around 50% with a 6.8V reading and then drops very fast (when charged from the laptop), dying within 15-30 minutes. When charged from an external charger and then running Battery Amnesia, it starts at 100% and drains over 90 minutes.
Maybe the issue is with whatever component is reading the battery voltage?
