IlikeTech
So I recently replaced the cells in my PowerBook 145B battery, and it works great, charges without a problem, and gets decent life. The only issue is the fact that the battery monitor build into the OS is designed for NiCAD Cells, when I recelled with NiMH as you can't get NiCADs anymore. Is their any way to patch the power meter to make it so that the estimate is half accurate/the system doesn't go nuts when the voltage sags a little?
Thanks!
Thanks!
