the clamshells boot 9 no doubt about thatbluekatt: 'dual usb' (according to this: http://en.wikipedia.org/wiki/IBook) should be a g3, so it must boot os 9.
Yeah, you'll probably need 9.2.2 on the CD for it.my 800 mhz dual usb G3 refuses to boot of my os 9 disc but that might be because i have 9.0
Although the Pismo has a physically bigger screen than the 12" iBooks, they both have a resolution of 1024x768. Therefore, you're not actually gaining any screen space by moving to the bigger screen. I personally prefer the slightly higher DPI that the 12" iBook offers over the 14" iBook or PowerBook.the pismo G3 powerbooks have bigger screen
but it is still a physically bigger screen in a bigger case i like the form factor of the icebooks and i donr mind the 12 inch screen but for some people its too crampedAlthough the Pismo has a physically bigger screen than the 12" iBooks, they both have a resolution of 1024x768. Therefore, you're not actually gaining any screen space by moving to the bigger screen. I personally prefer the slightly higher DPI that the 12" iBook offers over the 14" iBook or PowerBook.the pismo G3 powerbooks have bigger screen
yes, with no success.have you tried to remove the video card and reseat it.
this was one of the first thing i did.have you tried resetting Pram/Nvram by holding command+option+P+R at the start chime untill you hear the start chime 3 - 4 more times.
done.replace the video card with a known good Mac 8x AGP card.
thank you, trying these in a few hours. i really appreciate the noob-guide.have you tried to go into Open firmware by holding command+option+O+F at the start chime and type
reset-all (press enter/return)
set-defaults (press enter/return)
have you pulled the Pram battery out of the machine and let it sit unplugged from the wall for a few hours (if you do this remember which way the battery goes back in), let it sit for a minimum of 3 or 4 hours.
have you tried removing all but one stick of ram (if it has more then one stick) and turn it on, repeat the step until you go through all of the sticks installed by themselves. also try different ram slots.
