Snial
Hi folks, after much effort, this ol' Mac mini G4 is Alive 'n' Kickin'! It means I now have a complete-enough bridging range of Macs where the G4 bridges the gap between the PowerBook 1400c (Mac OS 8.1) and the MacBook C2D/2.4GHz.
And what a struggle it's been! This mini had always had a pretty dodgy hard disk, and when I re-acquired it about a couple of years or so ago I kept finding that whenever I booted it up under Tiger, it'd sometimes work for a while, maybe 30 minutes to half an hour and then would basically just hang. I eventually realised it probably was the hard disk so I cloned it as much as I could.
Then, since I bought the PowerBook 1400c, I've been thinking more about bridging each generation and eliminating all the other Macs I don't really need. In this case, it means the spare PB 1400cs; 2x iMac G3s, maybe my awesome PB G4 12" and iceBook/600 and probably my beloved iMac G5 (which has the GPU glitch issue). I bought a 128GB mSATA card + an IDE adapter last week and tried to hook it all up.
The adapter looks like it has master/ slave support. Unfortunately I can't yet get it to be recognised on the internal IDE. I've tried the drive with no M/S jumpers; slave jumper (I think it shouldn't have master) and haven't tried CS. I initialised the disk as APM with 2x 64GB partitions using the MacBook C2D (under 10.7) and then copied the salvaged disk image but that didn't work. I then found that the DVD drive doesn't appear to spin up and even delving into Open Firmware (educational as always, I love Forth ;-) ) didn't bring any joy - I couldn't see the partition!
I kept trying to insert my Mac OS 10.3 Panther installation CD, but it didn't spin up and then ejected the disk (then I found out it doesn't run anything as early as 10.3.0. So what followed was a lot of mistakes and gradual progress. Like: I found out it ran Leopard and I also have a Leopard DVD installation. But it needs 512MB I was pretty sure it only had 256MB. So, I realised my iMac G5 had 2x 512MB PC3200, so I could spare one - only to find that my mini did have 512MB x PC3200! Then, because the DVD drive wouldn't accept the Leopard disk either I tried using one of the iMac G3s in Target Disk mode to remotely install it, but it didn't seem to see the DVD when I booted the mini up with the option key. It didn't work either when I tried the MacBook in Target Disk mode!
Then I had a stroke of 'genius'! The iMac G5 could run in Target Disk Mode, despite the fact that it doesn't usually boot any more, because of the glitchy GPU. And - yay! The first bit of progress, I could get it to see the Mac OS X install disk and the iMac G5's HD. However, I still couldn't boot from the install disk (I kept getting the no-entry sign), but I could, it turned out, boot from the HD image (also running Leopard). Only to find that it couldn't see the mSATA drive there either.
At that point, I decided to swap in my old 60GB iBook HD (GPU issue again). This time I could see the HD! I still got the no-entry sign when I tried to boot from the Mac OS X installer. So I ejected it and found out it was the Panther disk I'd mistakenly inserted. What an idiot! So I found the Leopard one and tried again and this time it worked! In a mere 2 hours it installed Leopard on the mini ! And the G5 didn't die in the process, despite the vertical stripe screen flickering
It could work!!! Since then, I used the MacBook C2D to upgrade to 10.5.8 (I found the mSATA does work with the mini over USB-IDE). I found I still couldn't do internet sharing from my Mac mini 2012 (Catalina). But I can get access to the internet using a Raspberry PI 3 configured as an Ethernet Bridge.
And that's where I am now! It works! I'm really pleased! Now to install some iWork apps, Garageband and Final Cut Express! Then maybe do some retro video editing with an old Canon DV camcorder! I still need to figure out why the dvd drive won't spin up (it's no longer connected) and solve the harder-than-a-Rubik's-Cube problem of putting the lid back on!
Thanks for reading this tale of Merlot-enabled incompetence! Have a great weekend! Cheers from Julz
