pinto_guy
I recently acquired a Lisa 2/10 from its original owner, on Craigslist (SF Bay Area). It came with an original Lisa 1 mouse
p), and lots of software with manuals in mint condition. The cosmetic condition of the Lisa was impeccable, but it did not quite work. The screen was shaky, and you could tell that the Lisa did not want to boot. After two weeks of diagnostic/repair, I'm happy to announce that it's now working perfectly.
So here is the list of things that I did. If this post can help our community, that would be great. This is the intent.
1) Video board
- Recapped all electrolytic caps. This helped the video output quite a bit, but I still had a horizontal fold-over that the HOR PHASE trimpot (R34) could not fix
- Then realized that this trimpot was shot (open resistance). After I replaced it, the video was perfect
2) RAM Card
- One RAM card threw a "Parity Error". This actually did not prevent the system from booting, but it was annoying. I could not fix it, and ended up buying a replacement one on eBay ($125)
3) FDD
- We had the usual seizure of the eject mechanism, and the lubrication job did the trick
- There was a loud rubbing noise at every turn of the motor, which I eventually found came from a small plastic shim under the disk, that had a corner folded. This small fold was rubbing against the disk. That was an easy fix.
4) Widget
- Amazingly, the Widget initially worked. However, it died quickly and suddenly (read error #52 on NeoWidEx), and it took me a long time to fix
- Thankfully, I had a spare, working widget, and a series of swaps identified the culprit: The "Lizzy" chip (341-0301 U4 with green sticker on photo) on the controller card was fried. I had to purchase a spare card on eBay ($25 or so)
- However, even after the new chip was installed, I could not format the drive. It took me a whole afternoon of trial-and-error using NeoWidEx and BLU to finally succeed. I think what did it was to re-initialize the servo offset table. I cannot thank enough the great people (Tom Stepleton and James MacPhail) who give these fantastic tools to our community for free.
- Finally, I realized that the solenoid that holds the actuator latch was not working. Not a big deal since the widget still works without it, but the loud "clonk" when it releases is such a part of the widget, that I really wanted to make it work
- Found the culprit: a 2N4403 transistor (Q5) near the solenoid connector on the small card at the bottom of the drive (motor and solenoid controller) was shot (see photo in red, plus close-up). After replacement, a healthy "clonk" could be heard again.
Thanks again for all the great postings on this board that are of tremendous help. A youtube video was made, showing the latch-actuator mechanism during startup
1) Video board
2) RAM Card
3) FDD
4) Widget
