westcoastech
Hey guys
How hard do you think it would be to come by a Portable power adapter on its own, I would think pretty rare. Are any other power adapters compatible with the original Portable, are the plug sizes the same, voltage etc?
I have a chance to buy a Portable for $150 but it doesn't have the power adapter and as such it is unknown if it will turn on. It apparently worked when it was stored years ago, the battery is still installed on the inside (although most likely dead, hopefully it didn't leak but doesn't appear to have).
What do you guys think, is that a little expensive for a gamble on a Portable, I know they are rare although I don't really know that much about them, not really into collecting laptops but have wanted the original Portable.
Any help would be great, thanks.
